Mon, Jan 27, 11:42 AM CST
Subject: glass to look right
nick1 ( ) posted Tue, 26 August 2003 at 3:29 PM · edited Mon, 27 January 2025 at 1:37 AM
Hi all- I did a model of a 60's lookalike glasstop chair. When loaded in Vue and rendered without tweaking anything in final mode( using Wings material for transparency), I got the first image. Then in Vue, I tried different glass materials and ,again, without any tweaking, the results were not that much different. I rendered the second image using Lightglass material in final mode which gave me a bit more realistic glass behavior than the Wings image. Now couple of questions: First, for interior shots, which glass material and settings would give the desired glass look? Second, on the second image, what causes that blue area indicated by the arrow, and how can I get rid of it? Thank so much, Nick
nick1 ( ) posted Tue, 26 August 2003 at 3:30 PM
Here is the second image.
haegerst ( ) posted Tue, 26 August 2003 at 3:43 PM
I think the blue area is your sky reflecting in the glass... To see how good its really looking you should put it in a textured interior scene and youll get a better idea how the glas behaves... The floor and sky are too simple - you cant see how the glas is breaking light and reflections look just "blue"...
Vue content creator
www.renderarmy.com
haegerst ( ) posted Tue, 26 August 2003 at 3:48 PM
It also depends a LOT on the light, in interior scenes, you should turn ambient light off and work with pointlights - you can use these even in visible areas if you turn off Halo or use lamps or so... Use at least 3 lights, one as the "highlight" near the object and set your highlight with it. Use 2 other lights (spots are great) without shadows and softness about 5 to 10... Youll see the glass looks great... I cant remember who, but someone has posted a tut about that in vue here...
Vue content creator
www.renderarmy.com
Cheers ( ) posted Tue, 26 August 2003 at 4:43 PM
I think the blue (apart from the reflecting of the sky) is probably the "Fade out color" within the "Transparency" tab of the Material Editor for the material. Cheers
Twitter: Follow @the3dscene
haegerst ( ) posted Tue, 26 August 2003 at 4:49 PM
That could be, it applies if you set a value/color there... Good point on that, but I still recommend rendering the whole in a proper interior scene with proper lighting and the chair will strike...
Vue content creator
www.renderarmy.com
nick1 ( ) posted Tue, 26 August 2003 at 5:26 PM
Thanks guys. We will do just that and see what happens.I'll post an image later. If you think of anything else which would help, I am all ears. Many thanks again, Nick By the way, if you might need the model, post your email and I will send it to you.
MikeJ ( ) posted Wed, 27 August 2003 at 6:08 PM
Playing with the "refraction index" settings can make a world of difference. For what you want, you might want to try a higher setting.
haegerst ( ) posted Thu, 28 August 2003 at 3:18 AM
Yeah, thats a good point... And for glasses I would also try out the transparency and reflection sliders - by playing with these you can adjust the material so its looking more realistic, depending on what kind of glas you want to simulate... Never forget the proper lighting - THAT will make your glas look real...
Vue content creator
www.renderarmy.com
