Fri, Sep 20, 7:27 AM CDT
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Carrara Free Stuff here.
Subject: Alamo textures
robertzavala ( ) posted Tue, 14 October 2003 at 11:44 AM · edited Tue, 30 July 2024 at 8:30 AM
I am trying to texture a vertex model of the front wall of the Alamo by using shader domains and I'm probably doing something wrong. I only have 2 domains; the front and the top. The front is fine, it is flat shaded with a bump map and color map. No problem there. The problem is with the top shader, it is flat mapped with it's own color map but I can't figure out how to get it to have it's own seperate bump map. Does anyone know if this is possible?
TOXE ( ) posted Tue, 14 October 2003 at 12:27 PM
ehm, if i have understood well you need to have a separate bump map for each part of the object. Right? Usually it works by adding a multichannel. Have you made this? I post a little example of a cube with different bump maps. I hope this helps
robertzavala ( ) posted Tue, 14 October 2003 at 4:35 PM
Yep, still took me a while to understand how to implement it but I got it. Thanks
