Sun, Nov 24, 12:43 AM CST
Subject: Saving to library
MulaG ( ) posted Mon, 20 October 2003 at 11:30 AM ยท edited Sun, 24 November 2024 at 12:27 AM
I have my figure selected but can not save it to the library. The Option is not available in the menu panel under figures. Anyone know why?
Mason ( ) posted Mon, 20 October 2003 at 12:22 PM
There should be a + button in the figure menu. Are you sure you selected a body part? Sometimes poser will let you select the figure but you're really have focus on the camera or a light or something. Try clicking on the hip and make sure the figure and hip are selected.
MulaG ( ) posted Mon, 20 October 2003 at 12:41 PM
There are no icons. It looks like the figure is locked as it will not let me select any other body parts only the whole figure outlines in Red when I try to click elsewhere. I'm using Poser 5.
lesbentley ( ) posted Mon, 20 October 2003 at 1:02 PM
Sounds to me like the thing you are trying to save is not actually a figure. How did you load it? If you loaded it by clicking on an icon in the Figures pallet, then it is a figure. If you loaded it any other way then it probably is not a figure (if loaded via a pz3 it may be a figure). The way to tell for sure is to see if it is listed in the Figures menu.
Mason ( ) posted Mon, 20 October 2003 at 1:24 PM
Yeah that sounds like a prop not a figure. Did you load this via the figure folder or is this a prop you loaded or a mesh you imported. If you're not seeing seperate body parts then its not a figure. Figures are posable, props are static and have no parts to pose.
