Thu, Jan 23, 5:37 AM CST
Subject: Bryce not acting like real world "help"
steveb ( ) posted Sat, 22 November 2003 at 12:33 PM · edited Tue, 07 January 2025 at 12:25 PM
Hi all I wonder if someone can help me out on a problem i have just discovered in Bryce. I wanted to render a cup and saucer on a plane with graph paper mapped to it. For technical reasons i wanted the camera looking at the cup from 45 degrees to the plane. After rendering the image i noticed that the squares on the graph had changed so there was 23 across the saucer and only thirteen along the z axis which made the cup looked squashed. If you render looking straight down you get a perfect circle and the same amount of squares x and z. have tried different things, fov and stuff but it still comes out the same. Is this a perspective bug in the program or is it me. Any help would be great thanks Steveb
RodsArt ( ) posted Sat, 22 November 2003 at 12:42 PM
There is a perspective skew in bryce. Was your map tex squared? 512x512 or 1024x1024 ?
___
Ockham's razor- It's that simple
steveb ( ) posted Sat, 22 November 2003 at 3:57 PM
Thanks so much for that, you were dead on,when i check the texture graph image i had made a while back it was as you said not square. I new about using square images for the terrain but did not realize this worked for ordinary textures as well. Thanks again for you help Steveb
