Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:07 am)
Well, I've never used Zbrush to make morphs, but no morph should do this. How did you apply the morph? The usual import morph target dialog? Vicki has a separate head material, right? Try looking at that material in Surface Materials. Check that the Object Color is white and the Highlight/Ambient colors are black or dark, not anything weird, like bright red. I don't know how a morph would do this, but it looks as though the colors have somehow been changed. mac
Ah, now I see. Well, I'm really puzzled. The normals have no effect on morphs. They'll change imports, but not morphs. All a morph target does is tell poser what new position to move the geometry to when you turn the dial. I can't understand this at all. Let's try this a step at a time. You exported the head first. Then you morphed it in Zbrush. Then you added that as a morph target. Correct? If that's what you did, I can't see what went wrong. Sorry, but I'm baffled. Does the morph work OK? Is it just the color that's wrong? mac
Yes, that is what I did.
I am not sure that the morph is working OK. When I adjusted the morph dial to 1, it seems working OK. But the face is narrow if the dial value is less than 1, and wide if the dial value is larger than 1. I only modified the eyes when creating the morph target. I did not change the shape of the head.
Is this normal?
I had a problem like this in the face room once. It was a while back when I was more of a novice than I am now. I was simply adjusting bits and pieces in there when suddenly the head turned black. I tried replacing the black with head textures but it stayed black. I've got no idea to help you 'cos I ended up scrapping it and starting again. So if anyone finds a cure for this I'll be anxious to here it, just in case it happens again. 8) Catlin
Attached Link: http://www.pixolator.com/zbc-bin/ultimatebb.cgi?ubb=get_topic&f=1&t=009969
Pixolator posted a flip script on ZBrush Central so you don't have to export twice. Here's the link, the script is near the bottom of the first page. ArleenThere are a lot of things worse than dying, being afraid all the time would be one.
![file_86047.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_86047.jpg)
I was trying to create a head morph target of Vicky3 in Zbrush. For a simple test, I just modified the eye angle of Vicky3. Then put it back to poser, and applied the Vicky3 high resolution texture on her. I followed a DAZ tutorial Creating Morph Target in Zbrush by Glen Southern. The head is almost black in strong lighting as shown in the picture. I looked at Material room. The head texture was applied on her.What am I missing? Any idea what I should do to solve this problem?
Thank you.
