DAZ|Studio F.A.Q (Last Updated: 2025 Jan 01 2:42 pm)
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
-Anton, creator of
since 3-13-07
Yeah The countours are ver crisp in Studio. The nostrils, mouth and teeth are crisp. Thisit is just the material settings upon import
-Anton, creator of
since 3-13-07
-Anton, creator of
since 3-13-07
At least for posing, you can set the dials numerically by right clicking then typing the value. I'd assume it's the same for other areas. I just tried putting in a light and it worked, but I have no idea of the scale involved, so positioning it is going to take a bit of work until I figure that out. (Numeric is sooo much easier for me than sliding dials around!)
Anton, did you have to turn off the column's texture to be able to get reflections on it? Maybe that's what I was doing wrong. :) Thanks very much for these examples. SnowS
my DeviantArt page: http://snowsultan.deviantart.com/
I do not speak as a representative of DAZ, I speak only as a long-time member here. Be nice (and quit lying about DAZ) and I'll be nice too.
Anton, how do you get your render to look finished? I tried rendering Vicki and her hair comes out like a draft. It seems to be rendering what it sees in the preview. The hair looks blurred and it just doesn't look like a final render. Your render above looks fantastic! How do you set the render to look finished? Melanie
I turned the texture off on the column to get the reflection to be proper. Sliding the texture strength down would be an option as well. I love the pin lights(Lightbulbs) because they create beautiful gradients. I do not use the open gl for anything other than drafts and tests.
-Anton, creator of
since 3-13-07
Anton, when you say pin lights, can I assume you're talking about what I call point lights? (No dimensions, just an omnidirectional light that can be placed where needed.) If so, how is control of their placement handled? (X-Y-Z coords or by some other method.) Also, can they be placed inside a closed room and still illuminate the room? or better yet, can they be assigned to appear to come from an object designated to "looks_like (object)"?
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
