Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Great, Stewer! I've been trying to figure out what this Probelight thing was, but so far with little luck! Now I can read about it :o)
Excellent! Thank you very much stewer!!
What we do in life, echoes in eternity.
E-mail
| Renderosity
Homepage | Renderosity
Store | RDNA
Store
I've got one question: In the output from the 'probelight' program, it lists three values for each Lxx parameter; which one do we set the corresponding node value to? For example, when I go to set the L00 parameter in my node, I look at the output from probelight (using the kitchen probe): L_[0,0] 6.407946 6.751895 7.296709 I'm not sure which number I need to use, or if I should be doing some kind of summing, &c. Thanks!
The light probe is the one used in the last step of the tutorial, kitchen_probe.float, and the lightprobe is plugged in the ball's Alternate_Diffuse like in the very beginning. Don has the same material, except that his skin textures are plugged in the lightprobe's Surface_Color. Both Don and the ball have pretty much the materials that were used in the tutorial before. The floor has no lighbprobe node, it's just a tiles node plugged into the Ambient_Color (with Ambient_Value set to 1). The pattern comes from a cloud node that's plugged into the tile's colors.
"That government is
best which governs the least, because its people discipline
themselves."
Thomas Jefferson
Winzip should be able to open gz files thought. Have you tried associateing Winzip with them? (or Open With...?)
Attached Link: http://www.keindesign.de/stefan/poser/probelight.html
Topic says it - I just added a new tutorial to my web page. Realistic lighting easy and fast!
