Wed, Feb 5, 3:49 AM CST
Subject: Transparent Planes
Hdrider ( ) posted Wed, 30 August 2000 at 8:22 PM · edited Wed, 05 February 2025 at 1:31 AM
Hello, I am trying to use transparent planes and image files for some background stuff in Vue3 to cut down on polygon count. Problem: The planes aren't completely transparent. I'm getting a faint blue fringe. Anyone know the cure for this or is it just the nature of the beast? Thanks, hdrider
No good deed goes unpunished ...
BirdyH ( ) posted Thu, 31 August 2000 at 5:59 AM
Goto Atmosphere, Sky and Clouds, Sky tab, double click the color pane on top. now you can choose from a variety of colors for the sky plane. when rendering I can get a perfectly empty white sky. Hope this is the problem's solve. Harry
smallspace ( ) posted Thu, 31 August 2000 at 2:39 PM
Global Transparency should be set to 100% Variable Transparency should be turned on. In your Transparency Map, make sure that all transparent areas are completely white. Fade Out should be set to 0% (totally clear) CAUTION: Vue cannot render more than 5 layers of transparency on top of one another. At the 6th layer, all you will get is the fade out color (blue by default) -SMT
smallspace ( ) posted Thu, 31 August 2000 at 3:02 PM
I have noticed from time to time, a bug in Vue where one of the edges of a transparency mapped plane will show up as a very thin line when rendered. It doesn't happen all the time, and I'm not sure what causes it, but it can be very annoying as I have to get rid of it in post touch-up. -SMT
bloodsong ( ) posted Thu, 31 August 2000 at 6:49 PM
heyas; vue 4 should eliminate the transparency limitations. special hush-hush preview notice at vue e-groups... http://www.egroups.com/message/vuedesprit/2609
smallspace ( ) posted Thu, 31 August 2000 at 8:49 PM
...I Like it!!! Thanks for the tip off!
Sacred Rose ( ) posted Fri, 01 September 2000 at 12:22 AM
Birdy, smallspace, & bloodsong, thanks for the tips. :-)btw: Bloodsong....excellent preview. wooooohooo sounds like it could be pretty awesome. Sacred
Hdrider ( ) posted Fri, 01 September 2000 at 9:26 AM
Hello All, Well, I tried everyone's tips and am still getting the "blues". I'll put together an example of what I'm trying to do and post it. I think it isn't possible to do...yet...but we'll see. hdrider
Hdrider ( ) posted Sat, 02 September 2000 at 6:31 PM
Example1-2.jpg Here's a visual of what I'm working on. I've tried all the suggestions and they work fine with regular scenes but underwater is a different story. Any and all suggestions welcome. hdrider
smallspace ( ) posted Sat, 02 September 2000 at 9:54 PM
I would need ALL the transparency settings for both the water and the plane. It's possibly a refraction problem.
bloodsong ( ) posted Sun, 03 September 2000 at 10:51 AM
heyas; dunno. here's a tip though: do NOT use a jpg for the trans map. they have a tendancy to make the blacks un-black, and mess up the flat areas of colour with those lossy thingies. use a 256-colour greyscale gif. (or tif... shoot, now i cant remember... vue doesn't do gifs, does it?) hmmm... it DOES look like a refraction problem. i can see the top darkening looks like the underside of the water wave things...
Hdrider ( ) posted Sun, 03 September 2000 at 11:56 AM
Example3.jpg Hello All, Narrowed my problem down to (as was suggested) to the transparency refraction. I upped it to 1.30 and the "blues" went away. However, if I increase the highlight, it comes back. I'll try bloodsong's suggestion of using other types of images for the trans (been using jpeg). Again, thanks to everyone for the help. hdrider
