Wed, Dec 18, 8:51 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 17 1:08 pm)
Subject: Skintight clothes (2) easy with displacement map
vilters ( ) posted Wed, 14 January 2004 at 3:32 PM · edited Wed, 18 December 2024 at 8:50 AM
Second test; from left to right in one render: bare figure, with texture, with displacement map, complete. Biggest advantage : you never have a conforming problem with skintight clothing. Try it, it works.
Lawndart ( ) posted Wed, 14 January 2004 at 3:35 PM
Now THAT is cool!
TygerCub ( ) posted Wed, 14 January 2004 at 3:40 PM
I second the coolness factor! If you can produce that much exaggeration at the ankles and wrists for the edge of the clothes, why not the same amount for wrinkles? Do you think that is possible? I'd also be interested in seeing your displacement map to get an idea of the shading you used to get the different levels.
vilters ( ) posted Wed, 14 January 2004 at 3:51 PM
The map wat is the first post about this. But here once again, reduced. Tony The deepness depends on the grayscale value. White is most and black is no displacement.
vilters ( ) posted Wed, 14 January 2004 at 3:54 PM
This way U can use the P4-Lo figures as clothed background figures. And they don't eat resources. The previous post explains the procedure. happy testing, Tony
TygerCub ( ) posted Wed, 14 January 2004 at 3:59 PM
Wow! Thanks!
stewer ( ) posted Wed, 14 January 2004 at 4:06 PM
Attached Link: http://www.hdm-stuttgart.de/%7Esw19/files/dron_firefly_hi.AVI
You can use stronger bump maps to create helmets or shoulderpads, and it looks great when used with matching color maps.
vilters ( ) posted Wed, 14 January 2004 at 4:37 PM
That is corect stewer but .. A displacement map displaces the geometry and a bump map only gives the visual idea without actually displacing something. A displacement map even makes shadows that enhance the image. Look at the collars or the belt. You get real displacement, not only the illusion of.. even on this P4-Lo figure. It still needs further testing, but gloves, boots, bra's, panties, seem to be good canidates. And no conforming problems, even in extreme poses. See you all, it's bedtime overhere now.(Belgium) Next on the try list is a bra. Get the displacement with a displacement map, and the texture with a bump map. Could be interesting.
stewer ( ) posted Wed, 14 January 2004 at 4:41 PM
Woopsi. Was a typo, I meant displacements not bumps. Sorry.
DefaultGuy ( ) posted Wed, 14 January 2004 at 5:03 PM
Attached Link: http://brian.curiouslabs.com
Wow! That IS way too COOL! -Brian
vilters ( ) posted Thu, 15 January 2004 at 3:36 AM
Well, ik could work, but Poser misplaces the shadows!!! The shadow and highlight sides are reversed in the rendering.
Phantast ( ) posted Thu, 15 January 2004 at 10:03 AM
I've been doing this same thing with bump maps for a while, but displacment maps are better, for sure.
bip77 ( ) posted Thu, 15 January 2004 at 7:07 PM
Great! If - like vilters said - this nasty shadow bug wouldn't be, displacement maps could do great things in poser. But for slight displacements it's maybe ignorable. The clothes look very cool!
