Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 17 1:08 pm)
I second the coolness factor! If you can produce that much exaggeration at the ankles and wrists for the edge of the clothes, why not the same amount for wrinkles? Do you think that is possible? I'd also be interested in seeing your displacement map to get an idea of the shading you used to get the different levels.
Attached Link: http://www.hdm-stuttgart.de/%7Esw19/files/dron_firefly_hi.AVI
You can use stronger bump maps to create helmets or shoulderpads, and it looks great when used with matching color maps.That is corect stewer but .. A displacement map displaces the geometry and a bump map only gives the visual idea without actually displacing something. A displacement map even makes shadows that enhance the image. Look at the collars or the belt. You get real displacement, not only the illusion of.. even on this P4-Lo figure. It still needs further testing, but gloves, boots, bra's, panties, seem to be good canidates. And no conforming problems, even in extreme poses. See you all, it's bedtime overhere now.(Belgium) Next on the try list is a bra. Get the displacement with a displacement map, and the texture with a bump map. Could be interesting.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Poser 1, 2, 3, 4, 5, 7, P8 and PPro2010, P9 and PP2012, P10 and PP2014 Game Dev
