Sun, Feb 2, 7:46 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: Using Catharina's Displacement map for fur
  • 1
  • 2
DarkMatter_ ( ) posted Sun, 01 February 2004 at 2:45 AM
can you do body har like arm, chest and leg hair for Mike? I like what youdid with those eyebroes and the animals, Is this a mat file for sale anywhere?
KarenJ ( ) posted Sun, 01 February 2004 at 5:47 AM
Papa, I have been trying to recreate your Don haircut on M3 without much luck. Are you using one of the maps posted here, or something else?
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
mickmca ( ) posted Sun, 01 February 2004 at 10:44 AM
What a great thread. So cool to see folks using the stuff that makes P5 worthwhile. M
Mec4D ( ) posted Sun, 01 February 2004 at 10:57 AM
You can use the maps from message # 28 plug the displacement maps into the material and set the value of the displacement to minimum, you have to play a little bit becasue not all models need the same settings.. I think 05.00000 or 04.00000 will ok, change the diffuse color and Alternate diffuse to the right color of wish... how bigger the redners so fine and better the fur-hair effect. mickmca : it is for sure.. Poser5 have so much nice things that Poser4 never will allow you to do no matter what you do, I discovered that in some case the firelfy rendering make my work much faster as regular poser4 and is much more fun to play with on weekend ;))..
_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
wolf359 ( ) posted Sun, 01 February 2004 at 11:03 AM
what about an animated avi or gif of the noise map?? in the displacement channel I cant try it because movie node on P5 MAC OSX doesnt work has any one tried it.???
My website
PapaBlueMarlin ( ) posted Sun, 01 February 2004 at 12:27 PM
Karen, I used the displacement map in #28 with a setting of 0.3. Also be sure to setting the displacement ambience to something other than white or it will look odd.
Mec4D ( ) posted Sun, 01 February 2004 at 12:41 PM
sure wolf359 , I made buble on the skin but the rendering was little to slow, you can put a movie with talking head on the square and put it front of the doors, what a fine effect for horrors.. but first you need t prepare the movie.. make it little blur without noise other will a chaos..
daverj ( ) posted Sun, 01 February 2004 at 3:32 PM
I did some tests with AVI files used as displacement maps. It can give some nice effects. Of course it can take a lot of time since you have to first create the animation for the disp map, and then render the final animation using it to see the results (though you can render a few frames to get the idea first). It would be a good way to make throbbing veins in somebody's forhead, or that sci-fi effect of a creature crawling under the skin.
Mec4D ( ) posted Sun, 01 February 2004 at 3:50 PM
sci-fi effect of a creature crawling under the skin. that what I told you, the bubles was something as this.. you can use this for example to make effect as in the where the ghost move slowlly behind the painting or wall.. it is very cool option, self make simulation of grow slowlly fur.. or hair :) self the water effect.. just everything you imagine
DefaultGuy ( ) posted Sun, 01 February 2004 at 5:50 PM
Attached Link: http://brian.curiouslabs.com
"what about an animated avi or gif of the noise map?? in the displacement channel" "I made buble on the skin" What brilliant ideas!!! I'm going to try it later. -Brian
DarkMatter_ ( ) posted Mon, 02 February 2004 at 1:10 AM
someone could make alot of money on atmostpheres and hair mat settings....
Mec4D ( ) posted Mon, 02 February 2004 at 6:45 AM
if you can use the same settings for all models then well but that is not the case and every model is sensitive and need own surface settings including the light etc.. so simple is this not at all.. but can well included with own products that will works for sure.
DarkMatter_ ( ) posted Thu, 12 February 2004 at 10:46 AM
Catharina's displacement map for fur? Is that here or is that on her website and if it is, whats her url address?
ynsaen ( ) posted Thu, 12 February 2004 at 10:47 AM
scroll up
DarkMatter_ ( ) posted Thu, 12 February 2004 at 10:49 AM
is Catharaina's displacment map for fur a store itme or is it free some place?
Mec4D ( ) posted Thu, 12 February 2004 at 10:49 AM
See Message above number .28 there is the map :) cath P.S my web: http://mec4d.com but there you find nothing as only texturing stuff..
  • 1
  • 2
