I'll try it out, but did not see any description of its use for importing external morphs. Worth a look! :)
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Most definitely. And I have it here somewhere on my system, but as I said, this is my first Poser creation using morphs. ;) You may also want to check out my latest message. This is something that I have no idea about solving... Thanks, Kuroyume0161
off.
-- Bjarne
Stroustrup
I'm creating my first product with morphs... lots of morphs. Each morph is exported as OBJ from the modeling app, imported into Poser to get proper "Poser-ized" scale, then exported back as OBJ. After the base OBJ is loaded and turned into a figure, each morph is loaded one at a time. My inquiry is this: Is there a better, faster way/tool to create a figure with many morphs or is this standard procedure? Thanks all, Kuroyume0161
-- Bjarne Stroustrup
