Sun, Jan 12, 12:45 AM CST
Subject: Editing terrains
gillbrooks ( ) posted Mon, 01 March 2004 at 7:42 PM · edited Tue, 24 December 2024 at 9:13 PM
OK, another question....well 2 actually :-) If any of you have seen my gallery you'll know I use Bryce too. Now, if I edit a terrain in Bryce there are controls to smooth the terrain and to raise/lower it within the editor, neither of which I can seem to find in Vue. The smoothing tool is very useful for a number of things. The main advantage of being able to raise/lower in the editor is that if I've rotated say a symlat and want to then reduce the height it distorts diagonally (the same happens in Bryce unless you edit in 'object space' instead of 'world space' but if it's done in the editor then the problem doesn't arise. TIA for any advice
Gill
sittingblue ( ) posted Mon, 01 March 2004 at 11:31 PM
In brush mode, you can use the 'dig' and 'raise' brushes to lower and raise terrain. Also, in the effects drop down brushes, you can use 'diffusive erosion' to smooth bumpy areas. Otherwise, you can always export the terrain to a photo-editor program, make your changes, and then import the new picture into the terrain editor.
Charles
wabe ( ) posted Tue, 02 March 2004 at 12:56 AM
I think first of all you simply double click onto the terrain - to open the terrain editor. There you can find all kind of things you want to do with a terrain.
gillbrooks ( ) posted Tue, 02 March 2004 at 3:29 AM
Thanks for the replies but they don't really answer my question. I know how to get into the Vue TE but it doesn't have all the options that Bryce has I'll carry on doing it my way then which is create what I want in Bryce TE then import it into Vue.
Gill
erka ( ) posted Tue, 02 March 2004 at 7:26 AM
You are right gillbrooks. There is no way of making a terrain higher other than simply scaling it on the height axis. The result: streched mesh, ugly look. I don't know Bryce, but i dearly hope to see a similar option in Vue someday...
pisaacs ( ) posted Tue, 02 March 2004 at 9:17 PM
You can sugarcoat it all you want, editing terain in Vue sucks.
LrdSatyr8 ( ) posted Wed, 03 March 2004 at 4:55 AM
Attached Link: http://sittingblue.50megs.com/tutorials/mountain/index.htm
I just read a very cool tutorial on increasing the size of the terrain... I'm not exactly sure what you are trying to do, but you might want to take a look at this. -=> Jim! <=-
gillbrooks ( ) posted Wed, 03 March 2004 at 7:37 AM
Well I suppose it would only make sense to anyone who's used Bryce so I'm posting 2 images. This first is a terrain before smoothing. The small image in the corner is the nano preview from the Terrain Editor
Gill
gillbrooks ( ) posted Wed, 03 March 2004 at 7:38 AM
This 2nd image is the same terrain after I hit the smoothing button about 6 times
Gill
erka ( ) posted Wed, 03 March 2004 at 7:49 AM
Ah, This kind of smoothing is easily done in Vue. Just press the diffusive erode button repeatedly. I was assuming you were talking about a completely different problem.
gillbrooks ( ) posted Wed, 03 March 2004 at 3:14 PM
POIFECT!! That did it a treat. Thanks erka!
Gill
