Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 9:07 am)
Both the X-Wing and TIE Fighter were brought into UV Mapper and then I applied the "split verticies" option. The dead give-away is the sharp, straight edges- without the "split verticies" option, the wing edges would look rounded. And how do you do "phong shading" in Poser 4? :) --John
VanishingPoint... Advanced 3D Modeling Solutions
Here are methods that I can think of: 1) You would have to not split the vertitices, which would give a nice, rounded look. However, this would affect the wings and any square detailing on the cockpit area. 2) Make the model as pieces: the cockpit area can be imported without splitting verticies and the wings (and detailing) could be brought in with split verticies. I may give this method idea a try with the TIE Interceptor. :) 3) Be able to adjust the "smoothing angle": edges (90 degrees) would not be smoothed, but polygons on a sphere would be smoothed. Unfortunately, Poser has no way of doing this: the smoothing angle is locked at around 120 degrees (or so). --John
Yep, definitely send me the obj files and I'll add them to the zip files. And that B-Wing is pretty sweet looking! :) I'll have to try your trick with my next rounded ship. --John
Attached Link: http://www.vanishingpoint.biz/freestuff.asp?StartNo=58
Now available (for free) at Vanishing Point: the TIE Fighter, from *Star Wars*, *The Empire Strikes Back*, and *Return of the Jedi*. This model has been "optimized" for use in Poser... but unlike my other vehicles, this model is a prop (instead of a figure). No moving parts or texture maps are needed, but it's scaled to the Poser people Please note that this item is available only to members of Vanishing Point. Please login or sign up for a FREE membership to download this item. Above image rendered in Poser 4. --JohnVanishingPoint... Advanced 3D Modeling Solutions
