Wed, Feb 19, 3:48 AM CST
Forum Moderators: RedPhantom
Subject: Mil Dragon + Poser 5 = woes
odeathoflife ( ) posted Mon, 19 April 2004 at 1:50 PM · edited Wed, 19 February 2025 at 3:46 AM
Hey folks, I am making an image in poser 5 firefly using the dazmil dragon ( well 2 actually ) one has the Daz Dragon texture, and the other has the free HR dragon textures ( the gold ones available in the free stuff) but the wings on either are not working, I used the mat poses available from both, and it makes the falloff 1.0 so I figured that was the problem, so moved it down to 0 still rendering hte membrains as black, so I removed the trans map altogether, still black, so removed the textures and just used the material colour, renders black....I havn't a clue what ta do now. Any one else exper. this? Got's a solution? thx muchly. death
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
who3d ( ) posted Mon, 19 April 2004 at 6:20 PM
Umm.. MilDragon worked fine for me last time I checked... is the problem really blatant or might I have overlooked it?
Crescent ( ) posted Mon, 19 April 2004 at 7:09 PM
Did you try setting the displacement to .001 or so in the render settings? That might fix it. Also, set the fall-off to 0, not 1. This will keep the fall-off all the way up, all the way through. I always set my fall-off to 0 for transparencies. Hope this helps.
Lyrra ( ) posted Mon, 19 April 2004 at 7:43 PM
check where the trans map is plugged in, some P4 made MATS get it in the wrong place. Likewise for bumps.
Artalgo ( ) posted Mon, 19 April 2004 at 11:42 PM
Make sure that "Remove backfacing polygons" is not checked in the render settings.
odeathoflife ( ) posted Tue, 20 April 2004 at 12:40 AM
well not sure what it was actually ( I had another post here but now it is gone for some reason, showing the black membrains, and stating that I was just going to start from scratch as I loaded up another dragon and applied the mat pose to it and the wings rendered fine, so it was something that I did ( possibly that backface polygones thing ) any way thatnks for all the tips and thoughts. here is the image that I was working on. ( a little reduced in size)
♠Ω Poser eZine Ω♠
♠Ω My Homepage Ω♠
