Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
I don't own the M3 Millennium Beard so I can't confirm, but chances are good that the head does have Translate channels ... the dials are just probably hidden.
If you feel up to editing the Beard's CR2 file, you can enable the head's Translate channels by changing their "hidden" flags from 1 to 0. Or alternatively, I could email you a pose file that does it for you.
Attached Link: http://secure.daz3d.com/shop.php?op=itemdetails&item=1921
I believe this is the beard he is referring too... I dont have it either so I cant be much help... maybe it doesnt have the ability you are looking for?The picture is not of the M3 Millennium Beard - it's for a different beard. And unfortunately, the HEAD section for the M3 Millennium Beard does not have any translate dials. The only section of the beard that has translate dials that actually move the beard are under the HIP section, but they don't move the beard very intelligently
It would be great to talk to someone who has this product -- to see how they made it work.
Well...I just had an inspiration and opened up a new project with just M3 and the M3 Millennium Beard and it works fine. But I went back into my original project and the original problem persists. This is a huge project with six figures and many props, lights and buildings. Could this be causing the problem? I really need to bring this beard into this project because it must be worn by a figure who is a part of this big environment.
Oh, BTW -- In case this is important: I have Pro Pack.
Thanks for any help anyone can give me.
LR
The problem you might be having is the multiple figures. Often times (to fight crosstalk etc) I do each figure seperately and then export them as a prop .. this works for figures that don't have to interact closely etc (grappling or sometimes swordfighting) you then have to fiddle with things that are transparant but they generally work well ... If the figure works in a scene by itself this may be what you having to fight with.
The problem IS with multiple figures. I already have one M3 figure in the scene. When I bring another M3 in and then try to give him (M3 #2) a beard, it is conformed to the face shape of M3 #1 (even though it is pasted on M3 #2's face).
And then when I open the mouth of M3 #2, the beard does not move with it, although when I move his head around, the beard DOES move.
Another bizarre side problem that I just discovered is that when I put the M3 Millennium Beard on M3 #1 and open his mouth, part of the inner mouth parts of M3 #2 start to move as well (a hole opens up under his jaw). This is very strange. Help!
PS - This is a very small detail, but I still contend that there are no translate dials under the HEAD section of the M3 Millennium Beard. There are scale dials though. The translate dials are always found at the very bottom of the dial column and are labeled X TRAN, Y TRAN and Z TRAN.
PPSS -- Importing a second figure in as a prop won't work for me because I need him fully functional, for a fight scene.
I think that is crosstalk from what you are describing in the majority and that creates a lot of problems .. Option a. Work with the figures individually and make a temporary CR2 for them and then hope or b. Export them as obj's afer working with them individally. You cna possibly work with null figures as well but I don't think it will work with as many figures as you are talking about. good luck
YEEHAAAA! I figured out a work-around. The problem was that if I had two M3 figures in a project and added the M3 Millennium Beard to the second figure, it would conform its shape to the first M3's face and wouldn't morph when I moved the second M3's facial features. It would have been simple enough to just put the beard on the first M3. But I couldn't do that because I already had a M3 in a scene that I had painstakingly integrated into the scene and it would have been a lot of work to recreate him and place him in the flow of the animation, soooo...
I created two versions of the project. In the first project, I removed the first M3 and then added another M3 and added the beard. Then I removed everything BUT the first M3 from the second identical project and then imported him into the first project and he took his place exactly where I needed him. But I did run into one last glitch -- after I brought the second M3 (the one without the beard) into the first project, all of a sudden, the head morphs for the bearded M3 wouldn't work anymore (although the beard did fit him perfectly). So I removed all the morphs and injected them again (in the bearded M3) and now everything works fine. OY!!! (heh...not sure if what I just said makes any sense to you, but that's how it happened)
I am looking forward to hearing from DAZ tech support this next week about this issue. It seems like a definite bug.
I just downloaded the new M3 beard. When I apply it to M3, it doesn't do a very good job of starting out and I have to work quite a bit to get it to fit. (Yes, I did tell it to conform to M3). Too bad there is no conform to M3 dial.
And then I had to look and look in order to find a set of translate dials that would move it around (I found them under the hip category, of all places -- there are no translate dials under the head category)
Is there anyway to have the beard start out in place, like other hair pieces do?
Thanks!
