Thu, Nov 28, 11:55 AM CST
Subject: above and below
palagas ( ) posted Thu, 27 May 2004 at 1:56 PM · edited Wed, 13 November 2024 at 10:35 AM
Here is a picture I just made in Bryce. Trying this above and below water thing. All suggestions welcome. I'm still new at this.Tell me what you think
Zhann ( ) posted Thu, 27 May 2004 at 2:30 PM
Are you using a terrain for the water? It looks to regular? You need something more fractal/irregular...
Bryce Forum Coordinator....
palagas ( ) posted Thu, 27 May 2004 at 2:36 PM
Yes I am Using a terrain for the water. I'M just playing around with the settings, I'll try adding more fractal in the terrain editor, maybe that will help. Thanks for the input.
Henged ( ) posted Thu, 27 May 2004 at 3:32 PM
Try to use water not as surface but as volume, to do this press on water icon and hold mouse button
bikermouse ( ) posted Thu, 27 May 2004 at 5:02 PM · edited Thu, 27 May 2004 at 5:03 PM
No sign of refraction, diffusion of light below the water's surface, that play of lights from the water's surface(forget what they call that but there's a program that generates those that you can use as a gel in combination with a parallel light). Add a fish or two
you might check in the archives here. It was a hot topic about a year or so ago.
Keep at it you'll do fine if you can get past all the suggestions and develop your own style.
  • TJ
Message edited on: 05/27/2004 17:03
Zhann ( ) posted Thu, 27 May 2004 at 5:20 PM
Caustics, bikermouse...=) Some tuts that will help; URLS Underwater/ Over-underWater http://www.geocities.com/SoHo/Square/5391/oceantutorial.html=Making real oceanwaves http://www.renderosity.com/tut.ez?Printable=254 http://www.wolfiesden.com/flash/bryce/tut/adv-lighting2.html http://3dtoday.com/Tutorials/2001/Feb/BryceSurf/default.asp http://www.brycetech.com/tutor/bryce/underwater.html http://www.3dcafe.com/asp/tutorials/bryce/underwater/underwater.asp http://members.tripod.com/~JerryLS/tutorial1.htm http://lonestar.texas.net/~laewing/UnderwaterTutorial/underwater.html http://www.phazedance.com/3d/wavetutorial.html
bikermouse ( ) posted Thu, 27 May 2004 at 6:33 PM
Yes! I dunno why I fergetz dat! Thanks Zhann!
pakled ( ) posted Thu, 27 May 2004 at 7:20 PM
thanks, Zhann..
TheBryster ( ) posted Thu, 27 May 2004 at 9:29 PM
Forum Moderator
Here's a concept that works! Like this idea!
