Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
No sign of refraction, diffusion of light below the water's surface, that play of lights from the water's surface(forget what they call that but there's a program that generates those that you can use as a gel in combination with a parallel light). Add a fish or two
you might check in the archives here. It was a hot topic about a year or so ago.
Keep at it you'll do fine if you can get past all the suggestions and develop your own style.
Message edited on: 05/27/2004 17:03
Caustics, bikermouse...=) Some tuts that will help; URLS Underwater/ Over-underWater http://www.geocities.com/SoHo/Square/5391/oceantutorial.html=Making real oceanwaves http://www.renderosity.com/tut.ez?Printable=254 http://www.wolfiesden.com/flash/bryce/tut/adv-lighting2.html http://3dtoday.com/Tutorials/2001/Feb/BryceSurf/default.asp http://www.brycetech.com/tutor/bryce/underwater.html http://www.3dcafe.com/asp/tutorials/bryce/underwater/underwater.asp http://members.tripod.com/~JerryLS/tutorial1.htm http://lonestar.texas.net/~laewing/UnderwaterTutorial/underwater.html http://www.phazedance.com/3d/wavetutorial.html
Bryce Forum Coordinator....
Here's a concept that works! Like this idea!
