Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
With pictures as textures sometimes this can be a problem Deb. :O( On terrains or ground textures the picture needs to be really big.. The picture can be mirrored and even add turbulence and it still may not look right. One walk around is to use the picture as the bump map and then try and match the pictures characteristics with procedural colors. We are getting deep into material editing now. :O)
Well..I need to learn so PLEASE go DEEP LOL.... Damn...I've got plenty of rock textures, bit I need these or something similiar to go straight across. I'm doing a creek type thing that has rocks built up like the above only going straight across....arrggghhhh....I can't add individual rocks or my scene will TOTALLY out of control poly wise. As of now I'm up to 8m polys & haven't even finished with the trees or done the water..well the falls so to speak will be postwork or alpha's I'm sure.
Looks good...I just want my original pic I posted to have the rocks going straight across...so if what you did works..that's cool :). Awwww...I know you weren't implying I was thick ;)...Just wanted to let you know..realtively simple explanations work well with me LOL :).... I did try the applying the texture to a cube...but it looked so repetitive...lining up the cubes....looked weird...if that's what you are refering to in your above post....If not I just might be "thick" LMAO!!!! I do appreciate all your help :)
Attached Link: http://www.shoop3d.com/FREE/materials/debsrock.zip
I took nothing personal Deb no worries. LOL This is the texture on an Iceberg terrain and you can down load it from my site for now and see if it does the trick ok? :o) http://www.shoop3d.com/FREE/materials/debsrock.zipOpen up a terrain
Go to the terrain editor and click on reset
Click on eroded, then dunes, then iceberg
Click on ok
Apply your texture to the terrain
In the texture editor select: faces and click ok
In the scale of texture, outside texture editor, set size to .3
Turn the mountain around till you find a spot where it goes horizontally the most...
use that in your picture... :)
I found that the spot where it goes horizontally the most, will continue to do so, even after repeated resettings of the terrain... Hope this helps... :)
Message edited on: 06/20/2004 20:37
Thank You!!!! Sorry for the late thank you..but have been working & on the pic & lost track of time. I'll give your above instructions a whirl if that doesn't work I'd like to email you..but I need you addy ;).....IM me here if you don't want to reveal it publicly.
Message edited on: 06/20/2004 21:47 PS..I'm using Vue 4.2
Message edited on: 06/20/2004 21:48
As stated above. I'm trying to texture a terrain of rocks & I want the texture to go horiztonally instead of vertically. I've tried the arrow thingy in the picture box on the material page but when I switch it nothing happens. The terrain is an iceberg shape & the front face is still vertical. Any advice is appreciated :) Thanks - Debby
