Mon, Jan 27, 2:10 AM CST
Subject: 3DS to Poser Problems
Robo2010 ( ) posted Thu, 01 July 2004 at 9:58 PM ยท edited Sun, 26 January 2025 at 7:43 AM
Ok, I am doing texturing of Mechs like some of you have seen. I do em ok, and I am able to import 3DS, then export to Obj, then make texture files from UVmapping, then check it all in Poser......No problem. But, now..this mech was made in 3DS. Was told, legs, torso, arms move. Although in Poser, all I see is for height, location dials. Nothing else. I noticed this with all the 3DS files (mech) that I imported into Poser they only have dials for location, and rotate. What happened from 3DS to poser, when these parts are suppose to be moveable? Do I have to do this in Poser? I have Poser 5 with the SR4 patch installed. Oh..the Mech in the Pic (Texture), I did the texturing by hand in PS7, took a month a half. Still need work (Fixing) on the texturing.
Message edited on: 07/01/2004 22:00
xantor ( ) posted Thu, 01 July 2004 at 10:36 PM
Poser can`t import 3ds animation data so you do have to make the object work in poser, you can use the setup room and I would use bones from a figure that is already there and just delete any that are not needed ie the eye bones. CuriousLabs.com has a tutorial for using the setup room.
numanoid ( ) posted Thu, 01 July 2004 at 10:38 PM
Also search this forum for a tutorial by Dr Geep about Poserizing a figure. I used that for the Powerloader and it worked well.
geep ( ) posted Thu, 01 July 2004 at 11:13 PM
Hi Robo2010, You may ... [ CLICK HERE](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1649633) for the tut if you are interested. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Robo2010 ( ) posted Thu, 01 July 2004 at 11:41 PM
Wow..thanks guys, and Dr.Geep. :-)
SAMS3D ( ) posted Fri, 02 July 2004 at 4:19 AM
Hi Doc...have not seen you in a while, I have been busy, but I wanted to stop and say hi. Waving and jumping up and down....LOL Sharen
geep ( ) posted Fri, 02 July 2004 at 7:14 AM
Hi Sharen...I am glad you have been busy ...
(i.e., the devil makes use of idle hands,you know)
Thanks for taking the time to say "hi."
And ...Hey, I like that "waving and jumping up and down" stuff. You can do that for me anytime. LOL.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
