Sun, Dec 1, 12:50 AM CST
Subject: generic faillure !!!!
DonCorleone ( ) posted Sun, 18 July 2004 at 7:41 PM · edited Sun, 01 December 2024 at 12:48 AM
not long time ago... i impotr an obp in bryce 5.... and when i delete it.... almost objects i had in my import objects... dissapear. But now.. when i try to import obp objects... it's mark generic faillure. Can i remedy to this whitout reinstall bryce 5. Because i have lot of stock to reinstall back... (sky... materials... ) Help please DonCorleone
TheBryster ( ) posted Sun, 18 July 2004 at 8:13 PM
Forum Moderator
You could just un-install the corrupt obp directories, create new ones and re-install them, instead of a complete Bryce re-install.
Peggy_Walters ( ) posted Sun, 18 July 2004 at 8:36 PM
Attached Link: http://users.tns.net/~mwalter1/
Take a look in the directory and see if there is a *.tmp file. Delete it if it is there and try again. Check my site - I have empty object and material preset files for download. You can delete the ones that are broke and replace with the empty one. Hope you didn't loose anything important.
LVS - Where Learning is Fun!
TheBryster ( ) posted Sun, 18 July 2004 at 8:40 PM
Forum Moderator
Nice one, Peggy!
DonCorleone ( ) posted Sun, 18 July 2004 at 10:09 PM
the problem is... i cant import no more objects in the directories..... it's just tell me.... An unexpected error has occured ( generic failure ) and where it was objects before.... there are white screens.....
Ang25 ( ) posted Sun, 18 July 2004 at 10:12 PM
This might be because you have imported too many obj for one directory. There seems to be a limit after which the files corrupt. Not sure if this is your problem. If it is do what Peggy suggests, also create your own directories for storing objs.
DonCorleone ( ) posted Sun, 18 July 2004 at 10:39 PM
Thank's for help...... Don.
TheBryster ( ) posted Mon, 19 July 2004 at 5:00 AM
Forum Moderator
Don Corleone: Do what Peegy sez or we'll make you an offer you can't refuse..............;-)
Peggy_Walters ( ) posted Mon, 19 July 2004 at 7:44 AM
Are you opening the same file each time you have the generic failure? If so, it may be that the file has been corrupted. I also had a problem with a texture file having a file name over 32 characters long that caused Bryce to give a generic failure.
DonCorleone ( ) posted Mon, 19 July 2004 at 11:07 AM
I'm gone reinstall everything.......... take lot of time.................... Thank's for help.
