Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Quick answer: You Can't. Long Answer: You Can't. Informative Answer: It's rare that a file format such as OBJ (what I assume you are using) has the texture maps built in. Instead the OBJ comes with a MTL file that lets the program (carrara, in this case) know where to put the maps, and what groups everything is in. I'm not completely sure, but I think a few formats actually DO let you do this. Try 3ds. It's a good format to use any way. Otherwise, just slam all the maps back on it in Carrara's Texture room! Hoborg
On a related theme: Is there any way to import the ANIMATED PZ3 file into Carrara like you can with RayDream? Also, anyone know of the 3rd party (Th0r, for example) tie-ins for RDD been converted to C? Some folks have compared C to the combination of RDD & Infinity. I'd like to be able to dump the RDD if that were truely the case. Unfortunately--it's not:( Ray Dream's been very good to me--I just need the disk space!
I have been trying for the last hour to get a poser figure to import into carrara with all of the maps and so far I haven't had any luck. I just get the untextured model. how do I do this and get all the maps including tex bump and trans in?
