Tue, Jan 21, 3:48 PM CST
Renderosity Forums / MarketPlace Customers
Welcome to the MarketPlace Customers Forum
Forum Moderators: tim, msansing, ebasham
MarketPlace Customers F.A.Q (Last Updated: 2025 Jan 20 6:50 pm)
Contact and Support Information:
To reach our Marketplace staff, please open a support ticket at
support.renderosity.com
Our goal is to respond to support tickets within 24 hours, 7 days a week.
Subject: Aeris Hair Problem
Ethesis ( ) posted Fri, 27 August 2004 at 8:58 PM ยท edited Tue, 21 January 2025 at 3:44 PM
I'm sure I'm dense. I'm trying to change the hair to blue-white instead of blond, red or black. I've got the following settings:
Ethesis ( ) posted Fri, 27 August 2004 at 8:59 PM
And this is the texture file I'm using for both locations:
Ethesis ( ) posted Fri, 27 August 2004 at 9:00 PM
I can't figure out where the yellow is coming from. Any ideas? BTW, I'm using the above graphic for both places it calls to a graphic, not just one.
Ethesis ( ) posted Sat, 28 August 2004 at 12:01 AM
http://www.renderosity.com/viewed.ez?galleryid=750369&Start=1&Artist=Ethesis&ByArtist=Yes Problem went away between renders. You can see it in the WIP version. Well, don't know how that happened, but guess I can't expect a solution if there isn't a problem anymore.
danae ( ) posted Sat, 28 August 2004 at 4:07 AM
Hi Ethesis. I can't read your setings in the image too well but the yellow tinting in the bottom of the map is very weird. It's odd that you're not getting the results with the same setting in every render and I can only assume that this is yet another P5 glitch. Have you tried tweaking the settings a bit more to see if this goes away?
Ethesis ( ) posted Sat, 28 August 2004 at 8:47 AM
I tried all sorts of tweaks -- no joy. Changed out the maps over and over again (though I finally got one that I think is better for my needs than the one I started with -- the blue white one I have in minature), and then, suddenly, after a reboot (not that I didn't reboota number of times inbetween), it is gone. I think you are right that it is some artifact that just faded away out of glitchiness, though generally I've not had any P5 problems. Hey, my first P5 SR4 problem! Ok, I guess I shouldn't take glitches so lightly, but once they are gone. Problem gone here: http://www.renderosity.com/viewed.ez?galleryid=750369&Start=1&Artist=Ethesis&ByArtist=Yes graphic, same render with the problem in evidence: (and yes, it just looks like I've not applied the white.jpg to the entire hair set, but I had -- more than once, and to both jpegs -- which is why it was frustrating -- that yellow cast was carrying through on it and I couldn't find a reason for it).
danae ( ) posted Sat, 28 August 2004 at 9:11 AM
Your images looks wonderful! Hmmm, if it went away with a reboot then it almost certainly is your first P5 SR4 problem! Keep me posted if there are any more problems.
Ethesis ( ) posted Sat, 28 August 2004 at 1:51 PM
It is the hair and the KimiyA texture that make the character work. I'll let you know if anything else happens, but right now I'm happy as I can be. I'm just using the hair for this one character, so I'm hoping the problem is fixed.
