Tue, Dec 24, 11:50 PM CST
Subject: Lizard man thing needs your help
drhess ( ) posted Mon, 04 October 2004 at 10:19 PM ยท edited Tue, 24 December 2024 at 11:16 PM
Hi. I've been goofing around with textures and came up with this. Question: how do I get the seems to vanish? Do I just (or have to) mirror one side of the body to the other? Second question: how do I get the "scales" on him to be the same size even over parts of him that are moving or flexing? I just slapped the pattern down on the texture file for this draft.But is there a program for pulling and shrinking the texture such that it fits in side the vertices, or whatever they are, of a body map? Thanks.
EnglishBob ( ) posted Tue, 05 October 2004 at 7:27 AM
If you just apply a flat, continuous texture to a UV mapped model, it will tend to do that. Imagine that the map is an opened out version of the model's surface; somewhere there has to be a seam, and there are usually several. You would normally distort your map to achieve a seam free appearance, but this depends on knowing which bits join to which. SnowSultan has a series of seam guides in freestuff that will help.
RawArt ( ) posted Tue, 05 October 2004 at 8:29 AM
Welcome to the headaches of texturing...this is why not everybody does it. It takes alot of patience to match up seams, specially with a repeated pattern like scales. A cloning tool in photoshop becomes a good friend for that....but there really is no easy way (unless you have a program like deeppaint or something similar)
drhess ( ) posted Tue, 05 October 2004 at 1:51 PM
What's similar to deeppaint? Also, does the variance in size of the "cells" of the texture map tell you anything.
