Wed, Dec 25, 10:48 PM CST
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
Subject: Postwork
Enmos ( ) posted Thu, 14 October 2004 at 6:49 AM ยท edited Wed, 25 December 2024 at 10:37 PM
In the past some people asked me what kind of postwork i do on my images, so i thought it would only be fair to show you all :o) In my opinion i dont do a lot of postwork, most of the time the images look closer to like it was in reality after the postwork then they did before lol. I treat almost every image in the same way... i add some contrast and enhance the colors a bit... as you can see in the image. Its not world shocking but i just thought this would be a neat thread, especially if some of you would do the same :o) Just keep in mind that in order to upload the image i had to compress it considerably. So its not perfect quality... Btw. I use psp7
Jeroen
Message edited on: 10/14/2004 06:57
cynlee ( ) posted Thu, 14 October 2004 at 10:53 AM
well you have a good eye jeroen for in camera composition, where you're not needing to crop, then adding just the right amount of pw :]... i use PSP too... most all of my photos go through clarify & sharpen & maybe some contrast adjustment, smoothing & saturation... think a lot depends on the camera used... i've had to do less with this 5mgpx then i did with the 4... i would imagine it gets better moving up in cam quality & being technical adept at using manual settings... & my scanned images took a lot of pw to clean then up... there can be a lot of varibles to consider :]
Enmos ( ) posted Thu, 14 October 2004 at 11:14 AM
Thanks Cindy !! :o) I forgot to mention that i sharpen too, but thats obvious i think... if you resize youll have to sharpen. :o) I can relate to the hassle with scanned images, i shot some rolls of film some years back and scanned them... it was horrible lol But i guess a lot depends on the scanner quality. I can probably get the images out of the cam looking like my postworked ones, because i can adjust the contrast and saturation as in most cams... but i keep those settings on standard because i like to keep my options open hehe I hope to see much more posts here, its really interesting !! :o) Jeroen
Corwin13 ( ) posted Thu, 14 October 2004 at 12:37 PM
I join an example of my work! I use a freeware named Photofiltre to do that. Best regard, Patrick
cynlee ( ) posted Thu, 14 October 2004 at 12:44 PM
thanks for posting the original of this corwin, i was curious to see it :] like your use of this filter in many of your works
cynlee ( ) posted Thu, 14 October 2004 at 1:23 PM
ok... here's my contribution on "postwork" with some "cheating" in it :p (should we be giving away our secrets like this? :/) i liked the above left one, except for the bottom, so i took the bottom of the right & "layered" & "blended" it onto the left... i don't usually do this but wanted it perfect... "merged, "copied" & used a plug-in called "nik Color Effects Pro! 1.0e- Monday Morning" to give it that radiant glow, then layered the softer glowing version on top of the sharper one & "erased" back the parts i wanted in focus, this technique i learned from another photographer in the gallery so i hope i'm not giving away some magical secret i shouldn't of course there's the added frame with the drop shadow from eyecandy, i've simplified describing my pw technique here & compressed this image to fit i know a lot of postwork, but i luv doing it :]
Enmos ( ) posted Thu, 14 October 2004 at 1:33 PM
Patrick, i like your filter very much too ! Excellent crop btw !! Cindy, awesome job on merging these two images !! Must have taken some time... Thanks to you both for joining in :o) Jeroen
tvernuccio ( ) posted Thu, 14 October 2004 at 1:36 PM
This is a VERY interesting thread for me, Jeroen!!! First, hats off to your for your outstanding photography! You have many gifts...especially for composition!! Sometimes i use HEAVY postwork...sometimes i do like u...sharpen a bit, add contrast, enhance colors. I will post 2 examples of little post work and a lot of post work...but later...gotta run for now. Patrick...that filter is dynamite!!! really looks great!!!
Enmos ( ) posted Thu, 14 October 2004 at 3:44 PM ยท edited Thu, 14 October 2004 at 3:55 PM
Thanks Sheila !! Im glad you like this thread, im looking forward to your post here :o) And your work DOES NOT SUCK !! I saw the thread earliertoday but i didnt have the chance to react yet... I believe someone said that the most important thing isthat YOU like your work, it isnt important what others think ! I Agree with that ! As an artist you express yourself and that means you cant please everyone, its just like that. Take care, Jeroen
Message edited on: 10/14/2004 15:55
Corwin13 ( ) posted Thu, 14 October 2004 at 3:45 PM
I am blissful of admiration in front of this perfect work of merge, cynlee!! About my work, a precision: Photofilter is not a filter but a free software of treatment of images with many "classic" effects which I combine in best(?)... I hope that the other rates are going to come, it is very interesting! Patrick
cynlee ( ) posted Thu, 14 October 2004 at 4:11 PM
TY jeroen & patrick :] i do constantly strive for composition & technique within the cam viewer but am constantly tempted by the many possibilities of PW...i'm going to go google at Photofilter now :]
Akinom ( ) posted Thu, 14 October 2004 at 5:04 PM
Ok, I'll add one of my images, too :o) The first thing I usually do is to darken the shot but only a bit. I do it on most of my shots. In this one I added a very slight sharpening and cloned in the upper left corner as I found that part a bit distracting. Then I added the filter "equalizer". By using this filter mostly the light areas of the image get too bright and so I took away a bit of brilliance. Think that gives a more natural feel. That was all I did on this shot! BTW the "equalizer" doesn't work in every shot... I just play and look how it works. :o) Thank you Jeroen for this great idea! It's very interesting reading your thread and all the replies!
Corwin13 ( ) posted Thu, 14 October 2004 at 5:33 PM
@cynlee : www.photofiltre.com. Good night! Patrick
logiloglu ( ) posted Thu, 14 October 2004 at 7:03 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12379&Form.ShowMessage=1888377
regards
gerhard !!!!!!!! #:O) !!!!!!!!!
Corwin13 ( ) posted Fri, 15 October 2004 at 4:08 PM
Another example of my postwork. False sky, contrast, light saturated colors and an effect named "Inked outlines" (try to translate the french name: contours encr. Patrick
tvernuccio ( ) posted Sat, 16 October 2004 at 1:22 AM
Okay Jeroen, here's my contribution. I just uploaded this one in my gallery. First one is the original
tvernuccio ( ) posted Sat, 16 October 2004 at 1:23 AM
and here's the postworked version. i didn't like the compo so cropped...enhanced colors, increased contrast TINY bit, sharpened & framed.
tvernuccio ( ) posted Sat, 16 October 2004 at 1:25 AM
the face is too bright i think. hmmm...just noticed. should have worked on that. I'm beat and going to bed soon!!! love this thread! thanks Jeroen...and also for your encouraging words!!!! sheila
Akinom ( ) posted Sat, 16 October 2004 at 6:49 AM
Hey, guy'n gals... you're absolutely great! Thanks Jeroen for this fantastic thread... so much to discover here! Very interesting indeed! Thanks Patrick for dropping me a note. Your filter rocks. I should give it a try, too. Thanks also to Cyn, Gerhard and Sheila... we all can learn a lot by others :o) Hope there will be some more repies by others, too! Have a wonderful weekend all!
cynlee ( ) posted Sat, 16 October 2004 at 1:19 PM ยท edited Sat, 16 October 2004 at 1:21 PM
this thread is getting harder to download... maybe we can start a part II thread for more entries & post a link to it here & there you have a natural eye for those details moni, luved that tut gerhard, cool example of a dropped in sky patrick & a perfect crop shiela! :]
Message edited on: 10/16/2004 13:21
cynlee ( ) posted Sun, 17 October 2004 at 1:41 PM
Akinom ( ) posted Sun, 17 October 2004 at 3:17 PM
Thanks for the link, sweetie! mmmuuaahh
