Mon, Jan 27, 12:12 AM CST
Subject: NOOB Question about funky walks
autorenderphreak ( ) posted Fri, 15 October 2004 at 9:05 AM · edited Mon, 27 January 2025 at 12:04 AM
This is probably a common question - I noticed that during sometime during a walk sequence, one or two frames will have the knee doing something really weird, such as snapping inward. What causes this? How do I prevent it? ARP
autorenderphreak ( ) posted Fri, 15 October 2004 at 9:09 AM
Is this the famous "Gimbal Lock"??
SamTherapy ( ) posted Fri, 15 October 2004 at 12:34 PM · edited Fri, 15 October 2004 at 12:34 PM
I know nothing about walk cycles since I never do animation but I can tell you that it isn't gimbal lock.
Gimbal lock is the weird thing that happens when you rotate an object about the X Y and Z axes. You'd imagine that the model would remember which is which and move accordingly, right? Wrong. Eventually, one or more of the rotations will start to behave in a weird way and not move how you'd expect.
Message edited on: 10/15/2004 12:34
xantor ( ) posted Fri, 15 October 2004 at 4:11 PM
I think it is caused by the figure being a different height than the walk designer expects it to be. There is not much you can do about it except fixing the frames that are wrong by hand.
autorenderphreak ( ) posted Sat, 16 October 2004 at 10:51 PM
Is there way to fix it in Walk Designer?
ynsaen ( ) posted Sat, 16 October 2004 at 11:03 PM
That would be a no. Also, Walk designer does not work well with figures that are not grouped using the standard poser settings -- notably Victoria and Michael.
xantor ( ) posted Sun, 17 October 2004 at 2:28 AM
That is understandable, when the walk designer was written there was no such thing as victoria or michael.
autorenderphreak ( ) posted Sun, 17 October 2004 at 3:51 PM
Ah - makes good sense. Is there an updated walk designed that can work with Vic and Mike? ARP
xantor ( ) posted Sun, 17 October 2004 at 5:08 PM
Attached Link: http://www.nerd3d.com/Store/Front.htm
Nerd has made walk designer things to make victoria 3 and michael 3 work (at the link ) but they are not free.
