Mon, Jan 13, 3:59 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 11 8:46 pm)
Carrara Free Stuff here.
Subject: Alpha mask or transperancy blend?
Mun ( ) posted Tue, 30 November 2004 at 1:29 AM · edited Mon, 13 January 2025 at 3:55 AM
Attached Link: http://philipfong.tripod.com/id10.html
Can anyone tell me if there is a solution to alpha masking or transperancy mapped to cut away portion of a model? The edges appear to have a glow arround the croped section, I have tried both transperancy, oppacity, glow but nothing works. how do you do this kind of masking anyway? Thanks. Philip
TOXE ( ) posted Tue, 30 November 2004 at 2:16 AM
Hi Philip, on what version of carrara you working? In carrara4 the alpha channel work fine... But if i remeber well, in carrara 3 you can use multi channel mixer with single shader in the transparency channel, sorry i have uninstalled C3! -TOXE
TOXE ( ) posted Tue, 30 November 2004 at 2:25 AM
Ok, now i remember, this is an example without alpha channel... HTH -TOXE
TOXE ( ) posted Tue, 30 November 2004 at 2:51 AM
...or you can cut your models with Anything Grooves without alpha mask. -TOXE
falconperigot ( ) posted Tue, 30 November 2004 at 3:06 AM
That is so sad! :-(
TOXE ( ) posted Tue, 30 November 2004 at 3:23 AM
Sad? And this?
rendererer ( ) posted Tue, 30 November 2004 at 5:17 AM
This would be a fun contest - who can slice up this guy in the meanest and funniest way. :-D
Mun ( ) posted Tue, 30 November 2004 at 5:28 AM
Attached Link: http://www.3dcommune.com/3d/galview.mv?Carrara_RDS+amZbNFtFw+1101805336+&v_index=5&nd=1101820314
Yeaks! wrong link above, sorry here it is at 3d commune. I forgot that you can post image here. Thanks for the examples, I am still using C3 and the result is not like that, it seems like the croped area is not complete leaving glow edges. I'll try to convert the mask to greyscale.
falconperigot ( ) posted Tue, 30 November 2004 at 10:15 AM
Well, I reckon TOXE would win any MEANESS contest hands down (or is that hands up?). I just WEPT when I saw the holes in that poor guy. I shall join SCULPT immediately (that's the society to Stop Cruelty and Unpleasantness to Little Polygon Thingies) ;-)
TOXE ( ) posted Tue, 30 November 2004 at 11:18 AM
Sssssh, no, no an association called SCULPT doesn't exist. Maybe area 51, but not SCULPT. Shhhhhh. -TOXE
Pete_Exxtreme ( ) posted Tue, 30 November 2004 at 1:20 PM
LOL !!!!!! Excellent !
falconperigot ( ) posted Tue, 30 November 2004 at 1:48 PM
Hmm, well, I don't know about that....
Mun ( ) posted Tue, 30 November 2004 at 8:35 PM
a test on a simple sphere, I want the trasperancy to fade off but what I get is a harsh polygon and should not appear to look additive(lighter). Maybe I am looking for the disappear button.
falconperigot ( ) posted Wed, 01 December 2004 at 2:42 AM
Attached Link: Transparency shader tree
Mun, check out the method in this thread. If you still can't get it to work post a screen shot of your shader tree. It is perfectly possible to do what you want.
Mun ( ) posted Wed, 01 December 2004 at 7:32 AM
Hah! I got it! Its the blender, why an extra image map to do that, I was planing to use this technique on my new models but seems won't that increase file size or render time?
falconperigot ( ) posted Wed, 01 December 2004 at 12:48 PM
You can do it with one map, in the blender, with values of 0 & 100 in the transparency channels of the two sources. The number of maps you have will only increase file size if you save them internally. And it's using transparency which will increase the render time; using texture maps - as opposed to procedural shaders - will reduce render time.
Mun ( ) posted Thu, 02 December 2004 at 12:12 AM
Here is the test, I am using a few 3d applications and want to find the best possible solution to create obj models. Thanks, and fun chating with images too!
falconperigot ( ) posted Thu, 02 December 2004 at 1:23 AM
Looks good!
TOXE ( ) posted Thu, 02 December 2004 at 1:54 AM
I agree, really nice! You have modeled it with carrara?
Mun ( ) posted Thu, 02 December 2004 at 5:50 AM
It was from Hash and intended for OBJ export, it was edited in C3 to increase geometrical detail, C3 is able to edit while preserving the UV mesh. Apart from that I also do vector style and other renderings for models from Zbrush. Thanks for the help guys.
