Thu, Nov 28, 2:25 AM CST
Subject: Multi Figure inside project
alaint ( ) posted Mon, 13 December 2004 at 11:25 AM ยท edited Sun, 24 November 2024 at 9:47 AM
Hi there, I'm new to poser and need to create a multi figure project. First, I used a standard male figure and tried to add some cloth to it but double clicking the formal suit inside the library but it replaced the figure instead of adding a new figure. Then, I'm trying to add a second person in the project but it keeps replacing the same figure. Why is that? Regards,
randym77 ( ) posted Mon, 13 December 2004 at 11:37 AM
You have to click on the double-check mark at the bottom of the library. A double mouse-click or the single check mark will replace the current figure with the new one.
alaint ( ) posted Mon, 13 December 2004 at 2:44 PM
Thanks, that helps a lot. Now can you tell me how to add the clothing on a person. If you double click, it replaces, if you click on double check mark, it adds but it doesn't link the cloth to the caracter??? Regards,
randym77 ( ) posted Mon, 13 December 2004 at 2:53 PM
To link the clothes to the character, select the clothing. Go to Figure -> Conform To. Then pick the figure you want to dress.
This will only work if the clothing was designed for the figure you are using. If conforming doesn't work, the clothing is probably not meant for the character you are using.
Ben_Dover ( ) posted Mon, 13 December 2004 at 11:13 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&FAQ=Y
Here's a refreshing read for you as well. ;)
randym77 ( ) posted Tue, 14 December 2004 at 5:33 AM
I have to say...I think the FAQ is a bit off-putting, especially for people who might not speak English very well. That first question and answer is so long and technical, I think a lot of people wouldn't read past it.
Perhaps it would help if it was organized like Stefan's Firefly FAQ. All the questions are at the top, and you click on the question to get the answer. I think newbies are more likely to use the FAQ if they see their question is addressed right up front, rather than having to read through (or scroll through) a small dissertation just to see if their question is on the list.
nickedshield ( ) posted Tue, 14 December 2004 at 11:28 AM
One thing I would like to add- Before conforming the clothing, do a simple figure prep; turn off the IK for the legs and Zero the figure. This will help to prevent the notorious poke through, especially on the V3 Morphing Fantasy Dress.
