Tue, Jan 28, 4:50 PM CST
Subject: How to rotate a water plane so the wave go in the.....
dlk30341 ( ) posted Sun, 20 February 2005 at 8:52 PM ยท edited Tue, 28 January 2025 at 4:43 PM
How do you rotate a waterplane in order to get the waves going in a specific direction. I've tried roll to no avail...I want my waves flowing from right to the left not staright ahead. This is a procedural mat. TIA :)
Polax ( ) posted Mon, 21 February 2005 at 4:03 AM
One method (brute lol) would be to use a plane, not an infinite one with the material applied per object not world mapping With 4Pro you could even 'bake the water plane' : gives 2 polys! Then you can rotate the plane and texture will rotate with it The other way is to rotate the texture itself, whatever the mapping mode or the type of plane. mainly by rotating/changing the value of the z component from wave function.
dlk30341 ( ) posted Mon, 21 February 2005 at 8:43 AM
Thank you Polax will give that a whirl :)
regeer ( ) posted Tue, 01 March 2005 at 1:37 PM
The method i used with eg. the foamy water is , select the effects tap of the material and check the rotation in global transformation section. Than under edit rotate the water texture in the desired directions. I found this out lately when i got the same kind of problem whit the waterflow. Wim
