Jeff: You mean, the t-map for the uppers? When i did that, i got flesh-colored & white stripes along with the eyebrow, which made me think that somehow the marjorie head texture had gotten involved. Oh dear. i'm confused. Can you elaborate? You are kind to help. Joey: new morph! Wow, that is sweet. Makes me think that somehow the upper/lower eyebrow thing was supposed to be a subtle transmap like the hair, that somehow isn't working quite right. Again, many thanks-- Nan
You have two options with the eyebrows: Eyebrows is the material that is a part of the head mesh and it is textured within the face proper - the same as P4. It does not support transparency - there is nothing behind it. UpperEyeBrows is a material and a separate mesh - its position is controlled by "brows in" (it is tricky to position and there are donated morphs which abuse its location. Not mine. I hide it before I move any verts. It is usually one made with MAAGGnets.) The location for the texture is upper right on the head template. It supports transparency - the head is behind it. It works like transmapped hair. Two of the ways you can deal with it: 1-Do a full texture of eyebrows' fur on the map and use a transMap to define the outside shape. 2-Just put a patch of what you want the color of the fur to be on the texture map and define each strand of fur as well as its overall shape with the transMap. I have played with this, but we would be doing better if Kozaburo or someone with his talent took an interest in Vicki. This part is for Poser or Bryce or Cararra. Just exactly how you do this in the latter two prog. is for someone else to say, But Yeh Eovia!
![file_141341.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_141341.jpg)
Hi, i'm working on a Marjorie that's been ported into Bryce and having an awful trouble with her eyebrows. Reading previous posts and looking at BryceTech BryceAlive tutorial has helped--man, you guys know a lot! So i'm hoping that you will take pity on me and help out. When i used the regular marjorie head texture for her face & eyebrows (both sets), i got big heavy Groucho Marx eyebrows. i've hunted down a Vicki eyebrow+lash transmap and played with applying them (this is all in Bryce), but i get weird black lines around the edges of the upper eyebrow. i've messed with my own transmaps, with similar effect. Then i tried making the lower eyebrow flesh colored (invisible) and just deleted the uppers. Now she's just got shaved eyebrows. How can i get decent eyebrows back, without just going to post work? Many, many thanks in advance. You guys are cool! --Nan
