Thu, Jan 9, 9:38 AM CST
Subject: My new invention
kawecki ( ) posted Fri, 25 March 2005 at 2:49 AM · edited Wed, 08 January 2025 at 9:00 PM
After a long time thinking about I solved the problem. For any pose that you apply to Vicki the weights always points toward the ground, and it works with Poser 4 !!!!!!
Stupidity also evolves!
zulu9812 ( ) posted Fri, 25 March 2005 at 2:54 AM
a bit more explaining?
Helgard ( ) posted Fri, 25 March 2005 at 2:54 AM
and are you going to tell us how you did this, or do we have to belong to a secret club, lol.
Your specialist military, sci-fi, historical and real world site.
kawecki ( ) posted Fri, 25 March 2005 at 3:06 AM
For few bucks as 100,000$ you can belong to the secret club. The secret??? "Point to" to some object translated in the y axis -1000 or more units.
Helgard ( ) posted Fri, 25 March 2005 at 3:28 AM
Um.... where do I send the cheque to? I always wanted to be in a secret club.
zulu9812 ( ) posted Fri, 25 March 2005 at 3:28 AM
the old Object>Point At ?
kawecki ( ) posted Fri, 25 March 2005 at 3:45 AM · edited Fri, 25 March 2005 at 3:47 AM
First you have to create an articulated prop, in this case was a circular rope parented to the shin and a rope with weight parented to the circular rope.
You must set up the origin in the correct point of rotation and also the end point and correct direction, you can do it with the joint editor.
When you have done this the weight will be able to rotate correctly (not sepparating from the shin rope).
The last step is to use "point to" with the rope with weight.
Message edited on: 03/25/2005 03:47
kuroyume0161 ( ) posted Fri, 25 March 2005 at 5:11 AM
This trick is explained in "Secrets of Figure Creation", page 133 under "Gravity and anti-gravity".
 -- Bjarne Stroustrup
lululee ( ) posted Fri, 25 March 2005 at 11:12 AM
Very cool kawecki . Thanks for sharing this. cheerio lululee
lmckenzie ( ) posted Fri, 25 March 2005 at 6:35 PM
Waiting for the anti-bondage advocates to come with a rope for you :-)
kawecki ( ) posted Fri, 25 March 2005 at 6:50 PM
Bondage?, no!, she is Vicky and not James!
lmckenzie ( ) posted Fri, 25 March 2005 at 7:02 PM
Ah, didn't know Jimbo was into "a little of the old ultra-violence." A real whipping boy eh?
Acadia ( ) posted Fri, 25 March 2005 at 7:35 PM
Geez, my first thought was that this was some kind of BDSM fetish thread, lol
lmckenzie ( ) posted Fri, 25 March 2005 at 9:39 PM
Oh, but it is. See, we've roped you in already.
Nance ( ) posted Sun, 27 March 2005 at 6:44 PM
Three years prior to its description in Bloodsong's book, Darth_Logice also explored some of the potential of using Point-At to simulate gravity effects on hair and breasts in these threads. http://www.renderosity.com/messages.ez?Form.ShowMessage=58370 http://www.renderosity.com/messages.ez?Form.ShowMessage=58618
kawecki ( ) posted Sun, 27 March 2005 at 7:09 PM
Yes, I know that is an old thing, but it never worked for me. I used point to ground and the direction was not perpendicular in all positions. There is a gravity prop somewhere in the freestuff, it point to a virtual object well below the ground, but continue not working. I solved the problem when I set the "end point" of the junction with the joint editor and now is working. Setting the origen and direction is not enough!
