Wed, Nov 27, 12:38 AM CST
Subject: Ambient Occlusion Comparison
Fugazi1968 ( ) posted Sat, 26 March 2005 at 10:25 AM · edited Wed, 27 November 2024 at 12:36 AM
Hi All :)
I thought I'd do a comparitive render using ambient occlusion.
The AO image was created by adding an ao node to the face and body texture of aiko, and turning ao for the main white light.
So what do you think? I'm having a hard time deciding if I like it or not, especially since it took less than half the time to render the normal one. And the odd black smudge on her shoulder is annoying.
Then again I'm not completely sure I've set up ao as it was intended to be :)
Take care
John.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
pookah69 ( ) posted Sat, 26 March 2005 at 10:48 AM
Maybe it's just my eyes, but I see almost no difference--certainly wouldn't be worth the extra render time to me.
momodot ( ) posted Sat, 26 March 2005 at 10:58 AM
Am I just not with it? I only see a lower contrast on left and higher on right (plus the black facet on left). If anything, the fill light seems to be working better on right. What is going on? I thought I had descent visual perception although I do need a new glasses perscription for my birthday next week ;)
Fugazi1968 ( ) posted Sat, 26 March 2005 at 11:44 AM
As I mentioned I may have not set it up right :) but the differences I can see are around the eyes, the iris's look darker for one, and the neck and chest are darker too. The neck bothers me a bit, the shadow looks really dirty, if that makes sense. Ther render settings are one below final in P6 talk. Back to the manual I guess :) John
GWeb ( ) posted Sat, 26 March 2005 at 12:05 PM
Left with OA, I noticed very little of soft shadow. Her eyes got caught in shadow. I am not sure if you want it that way. The image really do not show the differences.
mateo_sancarlos ( ) posted Sat, 26 March 2005 at 12:18 PM
No big difference on my monitor, either. The AO is slightly worse, due to various artifacts.
maxxxmodelz ( ) posted Sat, 26 March 2005 at 12:30 PM
"The AO image was created by adding an ao node to the face and body texture of aiko" The purpose of AO is to produce "soft shadows", but your lighting in that scene does not compliment the use of it. You should try using IBL (image based lighting) on the light with AO. I dont think you have that light set as a diffuse IBL. Also, you can play with AO strength and (in the AO scene options for your light) try lowering the max distance a bit, while increasing samples slightly to get rid of artifacting.
wolf359 ( ) posted Sat, 26 March 2005 at 12:31 PM
This scene is not even close to being set up right for AO read your manual/tutes and check your settings.
My website
Spanki ( ) posted Sat, 26 March 2005 at 1:23 PM
I'm still playing with the settings, but here's some early tests... All images use 2 lights - Primary light is set up at 60% intensity, IBL, Depth map shadows and (in all but first image) AO. Secondary light is set up at 55% intensity, infinite, no shadows...
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
Spanki ( ) posted Sat, 26 March 2005 at 1:26 PM
first image has AO disabled... [notes: bright and cheery, but no flavor and no shadowing around fingertips, etc.]
Spanki ( ) posted Sat, 26 March 2005 at 1:27 PM
second image uses default AO settings... [notes: ok, has flavor, but teeth and eyes look rough}
Spanki ( ) posted Sat, 26 March 2005 at 1:29 PM
third image is an attempt to reach some middle ground between first two (settings to follow)...
Spanki ( ) posted Sat, 26 March 2005 at 1:33 PM
here's the settings for the 3rd image... Max Distance - made the rays cast further Bias - sample rays start a bit higher off the surfaces Num Samples - more rays are cast, for smoother shading ...note that final image with 16 samples was not a ton different than 6 or 9 in other tests, but adds to render time, so you should be able to get away with fewer samples.
Spanki ( ) posted Sat, 26 March 2005 at 1:35 PM
Ooops, I forgot one of the settings... Ambient Occlusion Strength - was lowered from (default) .7 to .45, to lighten up the shading.
Spanki ( ) posted Sat, 26 March 2005 at 1:40 PM
Observation... raising the Bias in the 3rd image probably hurt the shading around her right breast, where it meets the corset top. I think I can play with that value to make it more like image #2.
Spanki ( ) posted Sat, 26 March 2005 at 1:46 PM
Here's a side-by-side comparison.
GWeb ( ) posted Sat, 26 March 2005 at 1:50 PM
Did you use IBL AO and diable all other shadows?
Spanki ( ) posted Sat, 26 March 2005 at 1:51 PM
Note to John... "The AO image was created by adding an ao node to the face and body texture of aiko, and turning ao for the main white light." As mentioned by others above, you should use an IBL light and also, there's no need to add AO nodes to the materials. Just enable it on the light and it's calculated for the entire scene.
Spanki ( ) posted Sat, 26 March 2005 at 1:53 PM
"Did you use IBL AO and diable all other shadows?" My first post (post #9) describes the lighting used.
Danava ( ) posted Sat, 26 March 2005 at 1:57 PM
I agree that the teeth in particular suffer in the 2nd pic. I would almost be tempted to render both and then bring them into photoshop for a little "best of both worlds" merging. =) Really really cool to see this experimentation, thanks to you both!!
GWeb ( ) posted Sat, 26 March 2005 at 1:58 PM
Yeah the AO node, if is used for something else like fractal shadow, it is called "Nasty Shadow" because they did not use it with direct light interaction. Many members argued against my term because they thought the AO node would work the same with true AO. However the AO node may be used as true AO if you know how to use it with light settings and the light nodes. It may be renderer time saving. I still have not received my P6 box and am waiting to play with it.
GWeb ( ) posted Sat, 26 March 2005 at 2:01 PM
Spanki I just read your #9
Spanki ( ) posted Sat, 26 March 2005 at 2:01 PM
Here's another side-by-side of the bench area.
maxxxmodelz ( ) posted Sat, 26 March 2005 at 2:05 PM · edited Sat, 26 March 2005 at 2:06 PM
"I agree that the teeth in particular suffer in the 2nd pic. I would almost be tempted to render both and then bring them into photoshop for a little "best of both worlds" merging. =)"
In P6, you have the option to render a scene as "shadows only". So, in essence, what you can do is... render the scene one time without AO enabled (all your lights, including diffuse IBL should be on). This pass should render VERY quckly because there's no shadows. Save the image. Then instead of rendering the scene again with AO, you can turn on AO, and just render a shadow pass. This will be an all-white image, save for the darkened areas where shadows are. Then you bring both images into Photoshop, put the shadow pass image above the color image layer, and set the shadow layer to "multiply". Then your shadows are composited over your color layer.
To remove parts of shadows from the scene (like on the teeth for example), simply use the eraser tool on the shadow layer to remove whatever parts you want without affecting the overall effect. Message edited on: 03/26/2005 14:06
GWeb ( ) posted Sat, 26 March 2005 at 2:07 PM
If you like one of the shadows but not the teeth. I would add very little glow or ambient to the teeth. Hollywood have special teeth rembrandt for actors/actress for movie. In real life people have darker teeth.
nerd ( ) posted Sat, 26 March 2005 at 2:15 PM · edited Sat, 26 March 2005 at 2:16 PM
Forum Moderator
That's really not setup "right" when you turn on AO you would normally turn the shadow off for the light. Try it that way. If you do want shadows, use raytraced shadows. (You are already raytracing, might as well use it) Make them very soft and turn the shadow density way down.
Transmapped hair confuses the AO calculation (Imagine tring figue how all the layers interact with each other). Try using strand hair. It seems to go faster.
AO is also more for brightly lit scenes, ones where there would not be clear shadows or scenes using IBL.
You don't need to add an AO shader to every material in the scene. Only add one if you want to over ride the scene level AO settings for that material.
Nerd3D P.S. 3 lights all with AO on and shadows off. Stock AO settings except 5 samples
Message edited on: 03/26/2005 14:16
Spanki ( ) posted Sat, 26 March 2005 at 2:15 PM
But.. adding a very little glow or ambient to the teeth is called "Fake Teeth", because it does not use the proper settings and some people think it does, like True Teeth. [the rest of us get to make up terms too, right? ;)]
Spanki ( ) posted Sat, 26 March 2005 at 2:19 PM · edited Sat, 26 March 2005 at 2:23 PM
Thanks Nerd... I was using Depth Map shadows, because I hadn't yet figured out how to do the new softer ray-traced shadows (just adjusting the shadow density seems to have zero effect, for example). I'll look into that next.
"Try using strand hair"
The problem with strand-based hair is that it LOOKS like... strand-based hair ;).
Message edited on: 03/26/2005 14:23
GWeb ( ) posted Sat, 26 March 2005 at 2:28 PM
Spanki, "the rest of us get to make up terms too, right?" Right LOL :) GWeb
momodot ( ) posted Sat, 26 March 2005 at 4:02 PM
Thanks Spanki, I actually prefer the second render for some reason? But anyway, the test you did reall shows the difference in the left hand... gets rid of that "pasted on" look where meshes meet.
Fugazi1968 ( ) posted Sat, 26 March 2005 at 4:46 PM
Thanks to everyone for contributing :) especially Spanki who must have spent a long time doing all that work. I think I have a better idea of whats going on now :) I have had a look through the manual and tutorials provided with p6, and it leaves me a bit lost to be honest. Either they are not very clear or I am not very clever. Answers on a postcard please. Anyway here is a second attempt, the only difference being ao turned on on the left one, both using image based lighting. Take care all :) John
operaguy ( ) posted Sat, 26 March 2005 at 5:14 PM
bookmark
GWeb ( ) posted Sat, 26 March 2005 at 6:01 PM
John, "the only difference being ao turned on on the left one" Which AO were you talking about the node or the renderer? In my opinion the shadow in left kinda look dirt more like artifating. Is there a way you could soften the shadow? GWeb
jcbwms ( ) posted Sat, 26 March 2005 at 6:16 PM
It looks good -- however, it also appears the shadow bias settings are somewhat off -- assuming the program operates in a manner similar to the source for the rendering engine.
Spanki ( ) posted Sat, 26 March 2005 at 6:22 PM
Getting there John... to try to soften things up a bit, try either reducing the intensity of the IBL or reducing the 'Ambient Occlusion Strength', or both. If you want the character to be so brightly lit, try just adjusting the Ambient Occlusion Strength (it defaults to like 0.7, try loering that to 0.25 or somewhere inbetween), though I would at least tone down the light intensity a bit as well (maybe 80-90% instead of 100%).
yp6 ( ) posted Sat, 26 March 2005 at 6:27 PM
What causes the light "streak" where her upper left arm intersects the side of her chest below her armpit? (Her left arm, to viewer's right.) That should be even darker.
Fugazi1968 ( ) posted Sat, 26 March 2005 at 6:29 PM
Hey GWeb I didnt try it because of time factors but I'm told you can remove the dirt type effect by upping the sample rate, I left it at defauat, which is 3. I did up the strength level a bit too, reducing that would have softened the shadows too. I'm still experimenting :) Nerds post at 26 shows it off really well I think. John.
Fugazi1968 ( ) posted Sat, 26 March 2005 at 6:36 PM
Im not sure vp, I'm guessing thorugh that since ao works on lowering the ambient light when objects are close to each other, that part of the arm may be just out of range, so the light is not reduced. I hope that makes sense to someone other than me :) John
Tucan-Tiki ( ) posted Sun, 27 March 2005 at 12:37 AM
another figure
Tucan-Tiki ( ) posted Sun, 27 March 2005 at 12:56 AM
Second rendering playing with lights.
estherau ( ) posted Sun, 27 March 2005 at 1:56 AM
which figure and clothes is that Tucan-Tiki? He looks nice? Is it James? Love esther
MY ONLINE COMIC IS NOW LIVE
AntoniaTiger ( ) posted Sun, 27 March 2005 at 4:35 AM
Fugazi1968 I think the shadows come out a little too dark on the AO image, but it does show the effect. I don't recognise the figure but it does look to have the usual Poser joint problems, especially its left arm; wrist, elbow, and shoulder. The AO version makes the effects more obvious. My experience is that P5 can get close to most of the AO images in this thread, with a little careful adjustment of the lighting. But I'm wondering how many people have yet got a feel for the P6 improvements. Tucan-Tiki There's something about that guy's neck that's creepy.
