Sun, Jan 26, 3:40 PM CST
Subject: Shade 7 designer LE Serial # help!!
GothKurlz ( ) posted Mon, 11 April 2005 at 1:02 PM ยท edited Sat, 25 January 2025 at 12:19 PM
installed it and tried to put in the serail # that was emailed to be but it keeps telling me it's an Innocret. does anyone have any ideas on what i should do or who i should email? thanks ---Essie
DCArt ( ) posted Mon, 11 April 2005 at 1:26 PM
Attached Link: http://www.curiouslabs.com/article/articleview/20/1/289?sbss=289
>> does anyone have any ideas on what i should do or who i should email? Send an email to Curious Labs. All of the various contact information is on the page listed at the URL attached here.
Natolii ( ) posted Mon, 11 April 2005 at 1:27 PM
Make sure you are using zeros "0" instead of the letter "O". Always makes sure to use the Hyphens.
amberlover13 ( ) posted Mon, 11 April 2005 at 1:28 PM
I eventually, after emailing CL 4 times, called tech support at CL and finally got one. That would probably be your best bet. Another thing to try is to do a cut and paste of the number you got and see if that works. That's the only way I can make my P6# to work.
GothKurlz ( ) posted Mon, 11 April 2005 at 3:50 PM
thanks all, i had copy and pasted it but it kept telling me the same thing. looks like I should just call them and see what they can do. thanks again for your help.---Essie
Berkley ( ) posted Mon, 11 April 2005 at 6:44 PM
If you copy and paste the number from the email try backspacing 1 or 2 times (if that erases the last number just retype it back in).
I was having problems with mine doing copy/paste and then discovered it was adding extra spaces in, even though you couldn't see them.
Once I backspaced it worked fine.
GothKurlz ( ) posted Mon, 11 April 2005 at 9:03 PM
thanks I'll give it a try
