Tue, Nov 26, 6:42 PM CST
Subject: Problem with soft edges (phong shading)
bazze ( ) posted Wed, 13 April 2005 at 4:54 PM ยท edited Tue, 26 November 2024 at 6:26 PM
Hello everybody, I hope somebody can help me with this problem.
Ive just finished modeling the Dornier DO335 and Im about to start with the UV-mapping, texturing and bump mapping. The model will be released as a poser product later on.
As you can see in the image Im having problems with the phong shading. It looks OK in the C4D-version but the hard edges (edges with broken phong shading) turn soft (red areas) when imported into Poser (exported as obj from C4D).
What am I doing wrong?
Thanks!
www.colacola.se
thixen ( ) posted Wed, 13 April 2005 at 4:59 PM
do you have object smoothing turned on when you render? (It might be called polygon smoothing I forget ATM and don't have poser in front of me to check)
thixen ( ) posted Wed, 13 April 2005 at 5:02 PM
just checked it's called polygon smoothing
Little_Dragon ( ) posted Wed, 13 April 2005 at 6:58 PM
Technically, you're not doing anything wrong. Poser has simply been very unforgiving with its smooth-shading algorithms, at least until recently. The traditional methods of creating hard edges in Poser involve splitting the vertices along those edges, or adding a tiny bevel. Poser 6 has a new crease-angle feature that will usually correct the problem automatically, but that option isn't available in earlier versions.
Countach ( ) posted Fri, 15 April 2005 at 3:54 AM
Get a copy of UVMapper and on the tool bar hit Tools > Vertices > Split Vertices. The problem is that Poser renders polygons so that they will bulge. This is so that the figure models are more life like and without flat planes. UVMapper has a variety of tools to maintain dynamic geometry and weld polygons to make models more Poser friendly.
