Sun, Nov 24, 8:42 PM CST
Subject: Creating bioluminescence with P6 shader nodes?
Nalif ( ) posted Sat, 16 April 2005 at 11:48 PM · edited Sun, 24 November 2024 at 8:39 PM
I have an idea as to how to do this, but I'm not sure how nice it would look. Basically just create your texture map, and then create a black and white mask of the same texture, making the white areas where you want the bioluminescence to be. Then plug the mask into the ambient value node.
That's the most basic thing I can think of, though. The only thing this would really accomplish is the bioluminescence glowing whenever it wasn't under light, though. In normal images, where the figure is somewhat lighted, the other areas wouldn't appear to glow. They would just be slightly brighter than the surrounding parts. (I know, I know. Bioluminescence doesn't really show in the light anyways. I'm not after true bioluminescence. I just want certain areas to appear to glow.) Is there something that would give better results?
And while we're on the topic, P6 is amazing - but I wish they had an option to make an object illuminate other objects around it :( - You can make things glow in the dark, but they don't cast the light on things around them. I want glowing objects >_<
Message edited on: 04/16/2005 23:53
PapaBlueMarlin ( ) posted Sun, 17 April 2005 at 12:08 AM
I'm wondering if you would have to do a combination of an object with translucence mapping and a point light positioned inside it. By bioluminescence, I take it you're talking about things like lightning bugs.
Nalif ( ) posted Sun, 17 April 2005 at 12:23 AM
Yes - Lightning bugs, jellyfish, anything that lives in deep water, etc.
Little_Dragon ( ) posted Sun, 17 April 2005 at 12:46 AM
>> *.... P6 is amazing - but I wish they had an option to make an object illuminate other objects around it :(*
We do have such an option. It's called the gather node, and you can use it to create colour-bleeding effects (simulated radiosity) in the Material Room.
Here's an example, using an ambient material on a simple box prop, and a gather node hooked up to the ground plane.
Nalif ( ) posted Sun, 17 April 2005 at 12:57 AM
WHaaaaat? That's amazing. I remember looking into how to hook up the gather node, and for the life of me couldn't get it to work. So does it only "gather" the colors that bleed through the ambient channel? And how do I hook it up? Does it plug into the alternate diffuse?
Little_Dragon ( ) posted Sun, 17 April 2005 at 1:21 AM
There are a million different ways to hook it up, of course, but this is the setup with which I've experimented today. Don't forget to enable raytracing in your render options.
Little_Dragon ( ) posted Sun, 17 April 2005 at 1:22 AM
Another test render.
xoconostle ( ) posted Sun, 17 April 2005 at 1:25 AM
I hadn't tried the gather node before, but Nalif's question intrigued me, so I tried a quickie experiement by plugging the node (with default values) into the alternate diffuse channel of Ajax's floor tile texture on the ground plane. Now I'm looking forward to hours of happy gather node experimentation with other channels and values. Thanks Nalif and Little_Dragon! (Sphere texture is "Bacteria" by Stewer.)
stonemason ( ) posted Sun, 17 April 2005 at 1:34 AM
coolstuff LD!...I'd been looking for somekind of light emitting materials in P5
Cg Society Portfolio
Nalif ( ) posted Sun, 17 April 2005 at 2:00 AM
Stonemason: I do a lot of sci-fi modeilng along the lines of your work, and I've always dreamt of a way to make console buttons give off a glow "aura" with a material node. Unforunately, I don't even think this will let us do it. Those buttons always look so flat :(
Little_Dragon ( ) posted Sun, 17 April 2005 at 2:45 AM
Actually, I know how you can achieve that, even with the flat-panel controls you see in Star Trek. Place a one-sided square just above above the surface of the control panel, normal-side down. This will be your emitter. Enable "Remove backfacing polys" in your render options. The emitter itself shouldn't be visible when rendered, but the raytraced colour-bleeding still works.
semidieu ( ) posted Sun, 17 April 2005 at 2:47 AM
Wow !!! Incredible ! This is really cool !
Nalif ( ) posted Sun, 17 April 2005 at 3:09 AM
Here's my go at a jelly fish-like shader. Alright, so jelly fish don't have pink spots...but it looked cool ;)
Little_Dragon ( ) posted Sun, 17 April 2005 at 3:26 AM
I don't think jelly fish have hooves, either ... but I'll let that slide for now. :)
Nalif ( ) posted Sun, 17 April 2005 at 7:05 AM
Messed around for a few more hours and wound up with this. This is very close to a bioluminescent jelly fish. The scene has one infinite light behind the creature with mostly specular, and one spot light to the left of the image.
dirk5027 ( ) posted Sun, 17 April 2005 at 7:20 AM
guslaw ( ) posted Sun, 17 April 2005 at 7:55 AM
dlk30341 ( ) posted Sun, 17 April 2005 at 8:06 AM
Marque ( ) posted Sun, 17 April 2005 at 8:11 AM
tonymouse ( ) posted Sun, 17 April 2005 at 8:54 AM
bookmark Very very cool
Redfern ( ) posted Sun, 17 April 2005 at 9:07 AM
Oh! Now that's just damned clever, Little Dragon! I was wondering how one might go about creating a "repelling field" glow for the underside of a Dalek. I saw a clip of a "home made" Dalek prop/costume that had a lighting fixture rigged waithin the "bumper" section. An unearthly glow "bled" just beyond the "bumper" suggesting some alien electromagnetic field "levitating" the war machine (instead or simply rolling upon castors). From the few screen captures of the upcoming "Doctor Who" episode. "Dalek", I it appears they will employ similar visuals. I wondered how that (or even "if" it) could be accomplished within Poser. That is perfect! I will try that this afternoon when I return home. Sincerely, Bill
Tempt the Hand of Fate and it'll give you the "finger"!
nick_brown1967 ( ) posted Sun, 17 April 2005 at 9:08 AM
bookmark yes very cool
hemi426 ( ) posted Sun, 17 April 2005 at 9:45 AM
SamTherapy ( ) posted Sun, 17 April 2005 at 11:41 AM
Very coll stuff. Is there any way to simulate this in P5? I know about using the Ambient channel for self illuminated objects but how about a P5 equivalent of the Gather Node?
xoconostle ( ) posted Sun, 17 April 2005 at 12:51 PM
SamTherapy, good question. I don't have the technical know-how of L_D but perhaps you could use the color picker to sample the hue of the object that you want other objects to "gather," then apply that color to subtle shadowless soft spotlights aimed appropriately? What I want is a relfection catcher in addition to the shadow catcher. Imagine the possibilities if an object could be made invisible with the exception of relfective properties. By the way, I've seen biolumenescent jellies with pink spots at the Monterey Bay Aquarium. Nelif, your jellyfish node is beautiful. Cool work!
Ghostofmacbeth ( ) posted Sun, 17 April 2005 at 1:34 PM
Is there a way to combine it with another ambient channel? I am very new to the nodes and really have no clue about them.
PapaBlueMarlin ( ) posted Sun, 17 April 2005 at 3:02 PM
Ghost, you might use the blender node to create different ambient effects...
SamTherapy ( ) posted Sun, 17 April 2005 at 6:31 PM
"What I want is a relfection catcher in addition to the shadow catcher. Imagine the possibilities if an object could be made invisible with the exception of relfective properties." No problem. Gimme a few and I'll post the Material room settings.
SamTherapy ( ) posted Sun, 17 April 2005 at 7:50 PM
Here's a P5 Reflection Catcher.
c_hubert ( ) posted Mon, 18 April 2005 at 12:41 AM
bookmark
Singular3D ( ) posted Mon, 18 April 2005 at 2:30 AM
Connatic ( ) posted Mon, 18 April 2005 at 6:45 AM
I had to experiment with Gather after reading this useful thread. A sphere and a stretched sphere with materials, and one spotlight over a ground with tiles.
DistantWorlds ( ) posted Mon, 18 April 2005 at 12:29 PM · edited Mon, 18 April 2005 at 12:30 PM
Only one word: Beautiful! ;) BTW: I have good news about the Memory Bug from Poser 5 /6! ;) I recently received word from CL [QUOTE]Yes the engineers have found a bug that could be the cause of the problem. It will be in the first service release which will be out shortly. For know what I can suggest is two things. First, save out in revisions, ie save out to a different file name each time. Second you can add the entire scene as a prop to you library pallete. That way if the file does get over written you can just load it out of the libary pallete.[/QUOTE] Aren't these good news? ;)
Message edited on: 04/18/2005 12:30
jewell ( ) posted Mon, 18 April 2005 at 4:24 PM
Ooooooo.... Now I want time to experiment with the shader nodes, darn it. Must learn to give up sleep so I will have enough hours in my days.
xoconostle ( ) posted Mon, 18 April 2005 at 6:34 PM
SamTherapy, I wouldn't have come up with that reflection catcher solution on my own. THANK YOU! :-)
unzipped ( ) posted Mon, 18 April 2005 at 7:14 PM
bookmark
byAnton ( ) posted Mon, 18 April 2005 at 8:28 PM · edited Mon, 18 April 2005 at 8:29 PM
Just for a fun render could someone do a test render with the Magik Particle figure I made?
Anton MaterialRoomBookmark
Message edited on: 04/18/2005 20:29
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
SamTherapy ( ) posted Mon, 18 April 2005 at 8:52 PM
xoconostle, you're welcome. maxxxmodelz came up with the basic shader, which I tweaked to get the colour working, so maxxx deserves the credit.
byAnton ( ) posted Mon, 18 April 2005 at 9:22 PM
With what SamTherapy said and this glow technique you could recreate the StarTrek transporter effect by loading an avi in the transparency with noise going from total black to white. Just an idea.
Eismaus ( ) posted Tue, 19 April 2005 at 6:07 AM
bootmark
svdl ( ) posted Tue, 19 April 2005 at 6:15 AM
Cool! I can see flames actually casting light using this feature.
My gallery   My freestuff
Eismaus ( ) posted Tue, 19 April 2005 at 7:07 AM
Hm, i don't get it.. :o( What material settings does you use, to make your Probs (Box, Moon...) glow?
Dale B ( ) posted Tue, 19 April 2005 at 7:09 AM
Anton; If someone doesn't beat me to it, I'll give that a whirl this weekend (assuming the new new motherboard works). It'll be Thursday before I can start rebuilding the main system though, so if anyone else cares to go for it do!
byAnton ( ) posted Tue, 19 April 2005 at 1:11 PM
I have to go look for my old stuff. I uninstalled everything but my current projects. Just being lazy. hehehe.
Tirjasdyn ( ) posted Tue, 19 April 2005 at 1:30 PM
I'm working on one...maybe I'll have some tests up tonight. That's the goal anyway.
Tirjasdyn
byAnton ( ) posted Tue, 19 April 2005 at 2:34 PM · edited Tue, 19 April 2005 at 2:39 PM
A bit of experimenting but lots of fun. Faeries will never be the same in Poser. Someone should make sure Thorne sees this thread. Anton
Message edited on: 04/19/2005 14:39
Tiny ( ) posted Tue, 19 April 2005 at 3:42 PM
Very interesting indeed!
Bookmarking.
And more images pleeeeeaase! Love it.
Nalif ( ) posted Tue, 19 April 2005 at 7:39 PM
Here are some more images I've been playing with. These are Davo's creatures. I thought my material looked very "etheral", and then an idea struck me. I made the figure intersect the floor to make it look as if he's floating through the floor like a ghost. Turned out quite nicely with gather.
Nalif ( ) posted Tue, 19 April 2005 at 7:40 PM
Here's another one. This one doesn't have a gather node on the ground though.
Nalif ( ) posted Tue, 19 April 2005 at 7:42 PM
Doh. Wrong image.
Nalif ( ) posted Tue, 19 April 2005 at 7:43 PM
And here's one with the toonamal frog.
