Sun, Jan 5, 12:39 PM CST
Subject: Anyone getting P6 out of memory with Bumps maps
byAnton ( ) posted Sat, 23 April 2005 at 11:24 AM · edited Sun, 05 January 2025 at 12:35 PM
Hi there, In P6, when I use bump(jpg) on all my materials I am getting out of memory lock. Max map size is set to mid 3000's Anyone else having this problem. I have a gig of ram and a Radeon 7200. Anton
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
Mazak ( ) posted Sat, 23 April 2005 at 1:58 PM
In my opinion its not the texture size that causes memory problems.
I do 3 things to save memory for large scenes.
  1. Reduce max bucket size from 64 to 16 (P5 Standard is 32)
  2. Turn off Texture filtering (its a memory killer)
  3. Minimize the Poser screen if you render, that saves huge memory. (OpenGL eats a lot memory)
    Open the task manager to see the difference of memory use does render.
Mazak
Google+ Bodo Nittel
Tashar59 ( ) posted Sat, 23 April 2005 at 2:02 PM
I get it in both P5/P6. I reduce the size of all my maps and it makes a big difference. Bump maps are a killer. I try not to have to use them, many good textures don't need them even in close-ups.
byAnton ( ) posted Sat, 23 April 2005 at 2:31 PM
Thanks for the info. Good things to know.
DistantWorlds ( ) posted Sat, 23 April 2005 at 4:00 PM
How about Displacement Maps? I always get the out of Memory Message once I activate Displacement Mapping! :(
PapaBlueMarlin ( ) posted Sat, 23 April 2005 at 8:55 PM
The settings for bump maps are a little different for P5 than P6. I've noticed that the bump values for P6 need to be a lot lower otherwise your render will not only stall, but you probably won't get a good effect either. Also, it helps to increase the texture size as sometimes there will be a strain if you are trying to render larger textures at a smaller value.
