Sat, Feb 1, 9:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:10 pm)
Subject: a question about poser 5
SpiceHD ( ) posted Fri, 29 April 2005 at 7:21 PM · edited Fri, 31 January 2025 at 12:07 AM
Every time i clicked on a file that they cant find... i told the program not to search for it.. it does anyway and when it does it tend to make my poser 5 to crash... so why did that happen? why cant they find the files? and how do i get poser 5 to STOP searching for it when i told them not to?
Fazzel ( ) posted Fri, 29 April 2005 at 7:27 PM
The file is probably in a different location than the one given in the cr2 or pz3 or whatever you are having problems with. Try using a program called Correct Reference to get the right locations set into your files.
SpiceHD ( ) posted Fri, 29 April 2005 at 7:38 PM
Where do i get correct reference?
Fazzel ( ) posted Fri, 29 April 2005 at 8:48 PM
Try here
http://www.hogsoft.com/
Acadia ( ) posted Fri, 29 April 2005 at 8:59 PM
Quote - and how do i get poser 5 to STOP searching for it when i told them not to?
I don't think you can. I encounter that problem occasionally if I have played around with my runtimes (IE: renamed them), and my base figure is from the runtime under a different name. I haven't figured out how to get poser to comply when I cancel looking. It stops looking for that file, but keeps on looking for others...and eventually my computer just seizes up.
Francemi ( ) posted Fri, 29 April 2005 at 10:32 PM
Yes, I had that problem all the time with Poser 5. Another thing I love about Poser 6... it stops searching when I tell it to stop! ;o) France
France, Proud Owner of
KCTC Freebies
SpiceHD ( ) posted Fri, 29 April 2005 at 11:25 PM
Quote - I don't think you can. I encounter that problem occasionally if I have played around with my runtimes (IE: renamed them), and my base figure is from the runtime under a different name. I haven't figured out how to get poser to comply when I cancel looking. It stops looking for that file, but keeps on looking for others...and eventually my computer just seizes up.
I have exactly same problem it alway drive me nuts!
Francemi ( ) posted Fri, 29 April 2005 at 11:32 PM
As Fazzel said, you have to fix all the references in the Poser files. Using Correct Reference will save you lots of time and hard work. You could correct the references manually but you would have to open ALL Poser files (cr2, pz2, pp2 and maybe a few other formats) in WordPad and change the location of the referenced file (object, texture). Can you imagine the time it would take to do that?
KCTC Freebies
SpiceHD ( ) posted Fri, 29 April 2005 at 11:35 PM
im using correct reference and so far it havent found any incorrect files o.O
Francemi ( ) posted Fri, 29 April 2005 at 11:43 PM
Did you, by any chance, had this problem more often when applying morphs to V3, M3, etc.? If you did, make sure the !DAZ folders are in the main libraries folder and not into POSE or other folder. I had moved these files once and ... well you can imagine how often Poser 5 crashed! ;o)
KCTC Freebies
SpiceHD ( ) posted Sat, 30 April 2005 at 4:53 AM
it certainly is there i didnt move it :) i think some files i downloaded are missing some files
Francemi ( ) posted Sat, 30 April 2005 at 7:22 AM
Does Correct Reference find the fact that some files are missing? If not, I suggest ObjectOrganizer by John Hoagland (in the MP here). It will tell you if some files are missing BUT you have to check all files one by one. ;o(
KCTC Freebies
SpiceHD ( ) posted Sat, 30 April 2005 at 2:20 PM
all of files are in it correct places i left it overnight and checked all files like textures, libraries, etc... NOthing.
