Forum Moderators: Staff
heyas; note: poser is hard-coded to turn on ik chains of any ik chain named rightleg or leftleg. even if the leg iks are listed as 'off' in the cr2, they'll turn back on every time you load your figure. the solution, in the cr2, is to give the leg ik chains a different internal name. (the inkychain top listing.) you might want to do the delete and rebuild ik chain thing anyway. rebuilding it might help poser understand that this character is scaled, so the chain might behave differently. maybe. :)
Do the numbers at the bottom of this sequence mean somthing? inkyChain rightLeg { off name Right Leg addLink rThigh:1 addLink rShin:1 goal rFoot:1 linkWeight 0 1 linkWeight 1 0.05 }
"Your work is to keep cranking the flywheel that turns the gears
that spin the belt in the engine of belief that keeps you and your
desk in midair."
Annie Dillard
desk in midair."
Annie Dillard
Don't know much about those numbers, but the image you posted has a black background and the legs are black. I can't see the legs at all ;-) The feet look stretched. Deleting the IK chain in the HE is easy. Open the tree select an element and use the delete button on your keyboard. Creating a new one is done by dragging/dropping the leg and foot parts down to the chain name in the right order. I think it goes "thigh..>Shin..>Foot", the goal being last. -JH.
The streched part is between the top of the foot and the bottom of the shin. I'll have to trash this cr2 and start over with a previous version. I wouldn't know how to begin to fix this one. Thanks for the help, I'll try that.
desk in midair."
Annie Dillard
heyas; the shin is stretched because, somehow, the foot's ytrans is - something. when ik is on, the feet have trans dials, so you can move them around and the leg follows. when you turn ik off, the trans dials vanish, and the foot sorta... well, it's supposed to stay put. you can, theoretically move the foot off the end of the leg. it won't detatch however. if you see a little outline of your foot flying off the end of the foot body part...? that's an indicator of the foot's target. so if you try to pull the foot off the leg, the foot won't detatch, but the target will move down. if you then move the hip down, the foot will aim towards its target, and the leg won't bend til it hits. what i'm saying, basically is... it seems you've deleted the ik chain for the leg, but not the foot's translations. therefore, poser put the foot down where the trans dials told it to, and stretched the leg to fit it. (you can get the same effect if you load, say, the female head from the misc figures. if you move the head around the workspace, then replace the figure with a whole female, you'll find the head sticking off somewhere. :) ) those numbers at the end of the inky chain junk.... they mean something, but whenever you make an ik chain, they're always the same. lemur experimented with them. if you notice, they go in a particular numerical sequence. they shouldn't change if you create a new, scaled leg ik. (or, who knows? it might. lemur only experimented with normal/custom geometry, not scaled figures.)
You know how if you select a part there's a white outline? The stuff is between the shin and the foot, the white lines of neither part encompass it. What are 'foot translations' in the text file? Should I have deleted that too? That is what am I editing exactly to delete or correct the foot translations? All I did was search for all lines 'inky chain' and delete them.
desk in midair."
Annie Dillard
heyas; the trans dials are in the body part channels section. (cr2 section 2.) if you have a pc, you should really go to the poserTech egroups and nab compose 1.51. it'll make editing the cr2 a lot clearer and easier. the trans dials... actually, they are in all body parts, they are just invisible. go into the feet and open the xtrans/ytrans/ztrans and make sure all the values are zero (initvalue=0, i believe.) you can open a normal body part to see what the neutral trans dial should look like.
Thanks. I fixed it by cheating and starting over from scratch but I'm glad to have this for future reference. Thanks for all your help, now it's back to fighting with the tunic. Those previous settings no longer work :-(. I'm going to be old before my time...
desk in midair."
Annie Dillard
desk in midair."
Annie Dillard
heyas; that's not the channels for the foot. well, they are, but they are actually the shin channels for the foot. each parent has copies of its children's rots in it. i think the scaling is combining with the ik to confuse the legs as to where they think they should be. i think it'd be best if you take jeff h's advice and delete the ik chains inside poser, then resave the figure and see if it works. you can then rebuild the ik chains again afterward.
desk in midair."
Annie Dillard
heyas; yes, i'd say the foot is y transed. um.... i'm trying to remember if you can make the dials visible in the hierarchy editor.... jeff???! if you can show all parameters and go to the feet and find the trans dials and turn them on... do you poke the eye? is there an eye? (i dont use the hier editor much, either!) you should be able to fix the feet. you didnt go down far enough in the cr2 to get the foot dials. go to section two (after the second objfile reference thingy.) find actor rFoot. under that will be... blah, blah, blah, channels. under channels, search for translate. under translatey ytrans, etc, look for hidden 1. change THAT to hidden 0, then the dials will be visible in poser.
desk in midair."
Annie Dillard
What do you mean!!! "Who is this ScottA"? Didn't you read the memo? I'm PoserGod now. And I can fix anything. On your knees and tremble before my greatness! ;-) Hehe. Just kidding. I'm concerned with all of the messing around that's been done with the figure's .cr2 file. Sometimes they get too messed up to use effectively. Especially if you don't know what to look for. I'm also concerned about the default placement of the geometry as well. That will give you problems when using IK. If the figure is not touching the floor just right. you're asking for trouble. Most likely what will need to be done is this: 1.)import the figure as a prop. With drop to floor and center options checked. 2.)export it so it's now in the correct default position 3.)run the .obj through .phi builder and re-convert the model to a figure. 4.)set up the JP's again. 5.)add IK as the last step This is a lot of work. But it's fool proof. It works every time. Messing with a .cr2 and IK if the figure isn't at the proper default location is not fun. Even for people who know what they're doing. ScottA
I don't know that I can do all that. I play with morph dials and magnets :-). I did start from scratch again because I had the same thought, so nothing has been done to the jps on the current figure. The one where I fixed the jps looked good with ik off but bad with it on. Surely there is some way to edit the current file? I have already spent almost two weeks on a file that may not sell at all :-( I really can't see rebuilding the whole damn figure. All I did was to scale the figure down to 70% (y) part by part- chest abdomen thigh etc. Where and what is this 'proper default location' information in the cr2 file? I'd like to at least try it. I can export him as an obj and copy the info to the cr2 maybe?
desk in midair."
Annie Dillard
Hah! Sorry. That was a mistake. I also have a habit of spelling wonder as "wounder" My mind works a little strange sometimes ;-) I was only guessing you moved the figure around. If you didn't then don't worry about the default position thing. It's hard to guess what's going on. I can take a look at it if you zip up the .obj and .cr2 files and e-mail them to me at: scotta@rochester.rr.com ScottA
Oh thank you kind sir! If you just scale p4 man's legs down to 70% on the y and take ik off you get the same effect but I'll send the figure in case there's somthing else too.
desk in midair."
Annie Dillard
AhHa! Now I know what you're doing wrong. And it IS related to the default position. Sorta. If you rescale the shins and or thighs along the Y axis. The figure no longer touches the floor properly. And the result is this stretching effect. I'm sure I can get it to work. Next time you do this. Turn off IK first. Then re-scale the legs and then drop the figure to the floor. That way. Adding IK should work without problems ScottA
No you didn't ;-) I just did it to your files. And it works fine. Here's what I did to fix it: 1.)turned off IK 2.)select each thigh,shin,foot and select restore->element 3.)scaled Y axis to 70% for thigh, and shins 4.)bent the thighs and shins slightly 5.)select hip then drop figure to floor option 6.)set feet dials to zero 7.)turned on IK Works fine. Weather IK is on or off. The reason I bent the legs like that is because if they are straight up and down. the figure won't squat with IK enabled. Poser needs a little slight bend in joints for it to know what way to bend them using IK. I sent you a new .cr2 file with all the changes. I didn't have the textures. So you'll probably have to add them again. ScottA
desk in midair."
Annie Dillard
I didn't even have an rsr in the geometry file for p4 nude m, only for the gen version. I must not have the most recent patch, I'm going to try that. So just double checking, the render there is with ik turned off?
desk in midair."
Annie Dillard
I did, it still didn't work so I'm going to reinstall the patch now. I'd had problems with Vicki's catsuit earlier which also points to the patch. Fingers crossed again...
desk in midair."
Annie Dillard
Hooray! It works! Thank you very much for helping me. I wish I had figured out this patch thing a couple of weeks ago :-( I must've done somthing wrong installing the beta version by hand. I got the .exe version and now it works fine.
desk in midair."
Annie Dillard
"Your work is to keep cranking the flywheel that turns the gears that spin the belt in the engine of belief that keeps you and your desk in midair."
Annie Dillard
