Mon, Jan 13, 11:52 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Poser background
Nate ( ) posted Mon, 13 June 2005 at 8:35 AM · edited Mon, 13 January 2025 at 11:42 AM
I've heard that the dumbest questions are the ones not asked, but this one may be the exception.
Using Poser 5, but I've never been able to make this work with any version.
I would like to render with a plain background, without building a wall, so I go to the render options (same in animation setup) and change the background color. Regardless of what color I specify, the Poser grey is always what I get. If I go back to the render options... there it is still... grey.
Yes, dumb... but what am I missing?
Thanks
On-line portfolio / Making figurines in China / Gallery  / Video Demos
nikitanights ( ) posted Mon, 13 June 2005 at 12:29 PM
If I'm understanding you correctly you want to render on a plain bg color other than grey correct? If this is what you are saying ...
Image hosted by Photobucket.com
ON the bottom right hand of your model there's the four round buttons.... (Pink one in the image above is the bg button)... that's how I change the bg color... when I got to render I set it at "Render over BG color" and it works for me... did I help or was this post completely pointless... Runs back to corner
Nate ( ) posted Mon, 13 June 2005 at 1:20 PM
Thanks for the tip... however I have tried that... and everything else, but I still get grey. I used the little eyedropper - the dot as you show to show background color will not change ever from any color but grey. You will see that I made the other dots in colors... that one won't. I tried, as shown in the images, changing it in the display window, in the render options menu, and in the materials menu... never changes from grey. Image A shows the render with background as it always renders.
nikitanights ( ) posted Mon, 13 June 2005 at 1:37 PM
Hmmm I'm sorry I can't be of more Help Nate... I'm sure someone will reply with a suggestion or fix for you. GL! =0)
Acadia ( ) posted Mon, 13 June 2005 at 5:44 PM
Try changing the order you are doing things. From your pictures it looks like you are doing the render options first, before changing the background colour. Change the background colour first, and then do the render options. Also, try doing the edit/preferences and after selecting the background colour, do the save preferences and then the render options.
paper-tiger ( ) posted Mon, 13 June 2005 at 6:34 PM
I have always just used the paint bucket tool, clicked on the blank background inside the image, and selected a color without any problems. Could this be a bug, or maybe just making it more complicated than it needs to be?
jjsemp ( ) posted Tue, 14 June 2005 at 1:56 PM
This is a known p5 problem, in the material room, delete all the nodes connected to the background and you will be able to change the background again. It works the same for pz3s load the pz3 then delete the nodes and that is it. When you download the latest patch for P5 (if it's still available), there should be a README file. All you have to do is read it. And make a couple of clicks in the right places... takes just a second to fix. (this info was gathered from earlier threads about this problem) -jjsemp
hauksdottir ( ) posted Tue, 14 June 2005 at 3:59 PM
Yup. This was in the readme, and as jjsemp says, takes just a second to disconnect the nodes.
