Tue, Feb 11, 2:03 PM CST
Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
Subject: In Cam Color Matrix
jimry ( ) posted Fri, 17 June 2005 at 1:23 PM · edited Tue, 11 February 2025 at 2:00 PM
Which one do YOU use? Adobe RGB or sRGB? Just curious :)
Michelle A. ( ) posted Fri, 17 June 2005 at 2:01 PM
Adobe RGB..... I only convert to sRGB if I'm going to upload to the web or send it out for printing to a lab that requires images be in sRGB.
I am, therefore I create.......
--- michelleamarante.com
TwoPynts ( ) posted Fri, 17 June 2005 at 3:04 PM
Adobe.
tibet2004uk ( ) posted Fri, 17 June 2005 at 3:42 PM
Erm....what's the difference between the 2? O_o
Onslow ( ) posted Fri, 17 June 2005 at 4:55 PM
Mine outputs in sRGB so no choice unless I use a third party RAW processor like RSE2005. If I had a choice I would use sRGB as I often shoot in JPEG and I don't have a colour managed system from start to print capable of working in Abode RGB, so I would risk producing colours outside the colour gamut of the printer if I didn't.
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies live;
Their heads are green, and their hands are blue, And they went to sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
Michelle A. ( ) posted Fri, 17 June 2005 at 5:12 PM
Would you believe I just got 7 ebots from your one reply to this thread Onslow...... talk about a system hiccup......
Onslow ( ) posted Fri, 17 June 2005 at 5:16 PM
Sorry Michelle - I just deleted 6 (duplicate)messages - I hardly dare to reply :(
Edward Lear
randyrives ( ) posted Fri, 17 June 2005 at 7:42 PM
I do exactly as Michelle.
Wivelrod ( ) posted Fri, 17 June 2005 at 7:50 PM
Adobe RGB here - convert to sRGB before saving for web.
LostPatrol ( ) posted Fri, 17 June 2005 at 9:19 PM
Attached Link: http://www.drycreekphoto.com/Learn/color_spaces.htm
tibet2004uk See link, plenty more info do a Google for "Colour space" I use Adobe shot in RAW. I then convert all Adobe RGB images into sRGB into a separate directory as Jpeg ie Folder: todays_photos (contains RAW) Subfolder: todays_photos_psd (contains processed Adobe RGB) Subfolder todays_photos_jpeg (contains sRGB jpeg's) Subfolder: todays_photos_web (contains_websize sRGB jpeg) OK I am over through! That way I have Adobe files that I can use to print, and sRGB files at hand to use. All I need to do is concert to tiff as required.
The Truth is Out There
tibet2004uk ( ) posted Sat, 18 June 2005 at 2:02 AM
Thx for the link Simon!! Going to check it out right now! ;)
KiwiMiss ( ) posted Sat, 18 June 2005 at 4:08 AM
Ohhh glad you asked Pascale ... I was wondering the same thing
Noeline :D
~Predictably Unpredictable~
tibet2004uk ( ) posted Sat, 18 June 2005 at 4:33 AM
LOL@Noeline! Well, I checked the link out and, to be honest, I just didn't get it! A 'lil too complicated as an explanation for my taste! O_o Oh well!
vlaaitje ( ) posted Sat, 18 June 2005 at 11:31 AM
Adobe RGB so far I can see..haha
Ilona Krijgsman: My Tree Of Life
DHolman ( ) posted Sun, 19 June 2005 at 6:29 PM
Simplest way to think of colorspaces (also called gamut) is to think of a huge box of crayons. Each colorspace represents a different box that contains a specified number of crayons/colors than the others. sRGB's box is a lot smaller with fewer colors than the AdobeRGB box. sRGB contains the colors that are approximately what the average monitor can display.
LostPatrol ( ) posted Sun, 19 June 2005 at 7:22 PM
Now I wonder why I couldnt explain it that easily! Sometimes it is better to go back to basics when explaining complex things I guess. I use similar analogies when explaining files and folders and use a plain old filing cabinet with its file folders and drawers as an example. Very well put Donald.
tibet2004uk ( ) posted Mon, 20 June 2005 at 3:00 AM
Ooooooooh!!! Thx Donald my dear!! Now it's crystal clear! :) Now, how do u get an image to Adobe RGB? And I guess it's better for printing right! Would make sense! O_o
Onslow ( ) posted Mon, 20 June 2005 at 5:15 AM
It would depend on who was printing and on what. I have a 'run of the mill' monitor from one of the pc retail giants, and I print with a lab. who work in sRGB with Fuji Frontier printers which work very well with that colour space. If you have a high quality monitor and printer producing the finest results on a colour managed system, or are producing for commercial purposes embedding the profile to ensure the studio or agency sees it exactly how you intended, fine. Otherwise you could be making things at best difficult, possibly worse, by working in Abode RGB. If you are producing your images on a standard monitor which does not calibrate as the better ones do and/or are printing with a photo lab and/or are producing mainly to show on the web. Just my opinion for the experts to shoot down :)
Edward Lear
tibet2004uk ( ) posted Mon, 20 June 2005 at 5:19 AM
Mmmmmh! So in clear, u're saying it's best not to convert to Adobe RGB right?
KiwiMiss ( ) posted Mon, 20 June 2005 at 5:19 AM
Erm ... so this is an option on some cameras, the ability to chose between Adobe RGB and sRGB? As far as I can tell my Olympus C770 only does sRGB unless there's some key feature here that I don't know about in which case it sounds as though I should be shooting in Adobe in case I want to print and convert to sRGB for web? Have I finally understood all this? Ohh and what is RAW? Soooo much to learn and all this technical jargon!!!!
Noeline :D
tibet2004uk ( ) posted Mon, 20 June 2005 at 5:25 AM
RAW is "as taken"! No postwork is made in cam at all!! What u shoot is what u get in clear! When u shoot in jpeg, ur cam does some adjustements for u. when u shoot in RAW, it doesn't! It gives u the pic as it is! Not every cams have that option though! Mine doesn't! :(
KiwiMiss ( ) posted Mon, 20 June 2005 at 5:29 AM
Ohhh thanks Pascale ... mine doesn't either :-((( Another thing to add on my list of 'next cam must haves'
Noeline :D
tibet2004uk ( ) posted Mon, 20 June 2005 at 5:30 AM
LOL!! Yea, it's definitely on my list too! ;) What cam do u use Noeline?
Onslow ( ) posted Mon, 20 June 2005 at 5:32 AM
Not saying that at all Pascale - Im saying it is a choice depending on your equipment, end product and intended use. It has to be made in an informed way which is the best system for you to be working with, they both have their own advantages and disadvantages which you should be aware of before making the decision.
Edward Lear
KiwiMiss ( ) posted Mon, 20 June 2005 at 5:35 AM
Pascale my cams a Olympus C770 Ultra Zoom
Noeline :D
tibet2004uk ( ) posted Mon, 20 June 2005 at 5:36 AM
Mmmmmh! Ok Rich! But...how can I convert to Adobe RGB when my cam shoots in sRGB??
tibet2004uk ( ) posted Mon, 20 June 2005 at 5:37 AM
Ok Noeline! I'm gonna look it up! I like reading about other people's cams! I'm nosy I guess! ;) LOL!
KiwiMiss ( ) posted Mon, 20 June 2005 at 5:41 AM
Ohh goody ... would love to hear your opinion of mine vs yours ... Sony right? and what else I should be looking for in my next cam!
Noeline :D
Onslow ( ) posted Mon, 20 June 2005 at 5:46 AM · edited Mon, 20 June 2005 at 5:54 AM
Pascale - Mode - Assign Profile in PS and change your colour settings to make sure PS is using colour management and displaying in the embedded profile or displaying in Abode RGB.
Be aware though you must convert to sRGB and proof your image before: displaying it on the web or sending it to friends/family or sending it to printers working in sRGB or sending to anyone else who may not be working in a colour managed environment to see how it will look.
Message edited on: 06/20/2005 05:54
Edward Lear
tibet2004uk ( ) posted Mon, 20 June 2005 at 5:53 AM
Attached Link: http://www.dpreview.com/reviews/canoneos20d/
Ooooh! I'm no expert dear!!! But...I know that my next cam will probably be a Canon 20D! I'm also considering a Nikon 70D. These are DSLR which is what I want! Wonderful cams! I guess it depends what u want to do really! Here's the links to the reviews of both cams!
tibet2004uk ( ) posted Mon, 20 June 2005 at 5:54 AM
Attached Link: http://www.dpreview.com/reviews/nikond70/
And the Nikon 70D review! I'm looking for a link where both cams where compared but I just can't find it!! Still looking! To be continued! ;)
KiwiMiss ( ) posted Mon, 20 June 2005 at 5:58 AM
Thanks ... will read and dream for now
Noeline :D
tibet2004uk ( ) posted Mon, 20 June 2005 at 6:08 AM
Rich, sorry, but I just don't get any of this! O_o "Be aware though you must convert to sRGB and proof your image before..". My cam shoots in sRGB as I said earlier and what does "proof" mean? I think I'm just gonna leave it for now! But thx for ur help anyway Rich! :) Noeline, I know what u mean, I'm only dreaming of it too for now! Have to save first and these cam aren't cheap either so it will take a 'lil while before I can afford it! But hey...my 'lil Sony is pretty cool and I love that cam so it's ok, I'm not longing too hard! ;)
