Sun, Nov 24, 6:15 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 24 4:22 pm)
Subject: common prblem im sure...
icandigit ( ) posted Tue, 02 August 2005 at 8:19 PM ยท edited Sat, 10 August 2024 at 8:05 AM
For some unknown reason, when I tried to load my Poser 3, I got a "not enough memory to run Poser" error... What's the deal with that? thanks :D
Tunesy ( ) posted Tue, 02 August 2005 at 8:24 PM
...at the risk of sounding trite I'd guess you don't have enough memory ;) Is your comp as old as P3? )
mateo_sancarlos ( ) posted Tue, 02 August 2005 at 9:31 PM
P3 didn't need much memory. It's probably a question of a new OS being incompatible with the obsolete app.
icandigit ( ) posted Tue, 02 August 2005 at 10:44 PM
i can assure you, it is not my operating system, or that i dont have enough memory... i have been using poser for quite some time now, dont know what caused this...
xantor ( ) posted Tue, 02 August 2005 at 10:49 PM
I had a similar problem with poser 4 on my computer, you could try reinstalling it but uninstall first so that none of the old data is left behind because it might have got corrupted some way.
icandigit ( ) posted Wed, 03 August 2005 at 12:19 AM
had to reset paging file to get it to work... thanks anyway tho guys :D
xantor ( ) posted Wed, 03 August 2005 at 11:06 AM
You would be much better off with poser 4, it can do much more than poser 3 can.
icandigit ( ) posted Wed, 03 August 2005 at 11:21 AM
i have this italian disease you see... "myfundsarelow" :P
xantor ( ) posted Wed, 03 August 2005 at 12:58 PM
That was what I thought, but 4 is much better.
icandigit ( ) posted Wed, 03 August 2005 at 3:11 PM
honestly, ive gotten so used to using poser 3, and that it still does serve me very well, i havent the need for anything better... daz studio was a HUGE boost to what i can do and use, but i still havent seen the need to get a better a version... ( ( ), as there is always a but somewhere, the reason i needed poser this time was because i wanted to start making poseable models, and not until now did i have a need to upgrade... thanks...
EnglishBob ( ) posted Thu, 04 August 2005 at 4:12 AM
The problem is actually too much memory. When Poser 3 was released, 1GB RAM was an unimaginable amount - nowadays it's commonplace. Poser 4 had the same problem to begin with, but a patch was released to fix it. Poser 3 was never fixed. Sorry. :( If you do upgrade to 4, you won't look back.
