Sun, Jan 12, 1:50 AM CST
Subject: Important request for information to all Poser 6 Sr1 Users from PXP
PXP ( ) posted Mon, 08 August 2005 at 3:37 PM · edited Sat, 30 November 2024 at 1:12 AM
Over the last eight weeks I have been running Poser 6 SR1 on two high end PC's. Both machines have developed very strange behaviors and have developed similar problems. The mouse becomes difficult to use and starts to drag, it is painful trying to move Poser parameter dials and becomes so slow that the software stops working - these PC's have 3.4MHz processors. Both machines eventually freeze and wont do anything and cannot be used for at least twentyfour hours after switching off which is also strange.
Both machines been checked with the latest Norton AntiVirus for virus's, worms etc and they have both been scanned for mallicious software and spyware and are clean. The operating systems have been reinstalled but the problem returns. Because Poser six makes use of Graphic card acceleration and works differently from Poser 5 I am asking if anyone else is experiencing similar problems or has had anything like this and can offer advice and help. I am not saying that I am convinced that Poser 6 is directly responsible for this but it is the only software that I use where the problem starts to occur, it does not happen with any other software that I am using.
My hard drives have been checked and are working fine. The computer hardware appears to be in good working order.
PXP
thefixer ( ) posted Mon, 08 August 2005 at 4:10 PM
Not had this with Poser 6 but I did have some very strange problems with my Nortons anti virus, system clocks going haywire, lock ups etc. Moved my anti virus to AVG and it's been ok since. Might be an idea to look at Nortons instead of Poser! thefixer, poser coord.
Injustice will be avenged.
Cofiwch Dryweryn.
originalkitten ( ) posted Mon, 08 August 2005 at 4:15 PM
i have p6 sr1 ......and I dont know if its connected but I have a cordless mouth that has behaved erractically.....but on other programs too. In fact Im thinking of swapping my mouse with my sons optical corded one....
"I didn't lose my mind, it was mine to give away"
SamTherapy ( ) posted Mon, 08 August 2005 at 4:29 PM
When my cordless mouse started acting up I changed the batteries. Worked a treat after that. Not had the problems you mentioned with P6, either.
richardson ( ) posted Mon, 08 August 2005 at 4:29 PM
Only a few things come to mind; update your drivers. Switch off other open apps. Switch from open GL back to Scree3D. Probably not the fix but covers a few loose ends.
svdl ( ) posted Mon, 08 August 2005 at 4:36 PM
I've only had these problems when another OpenGL using app was open at the same time (in my case 3DS Max).
My gallery   My freestuff
randym77 ( ) posted Mon, 08 August 2005 at 5:07 PM
I've never had this problem, and I've been using Poser 6 for months. I don't have Norton, though. Well, I did, but it caused so many problems with other programs that I removed it (as best I could).
odeathoflife ( ) posted Mon, 08 August 2005 at 5:18 PM
No never had this problem, running a 1.8gig semperon onboard vid, no slow downs no problems, but I would say this is norton and not poser, norton has really gone downhill with compatibility the last few years.
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Porthos ( ) posted Mon, 08 August 2005 at 5:33 PM
I don't have any problems either and I have Norton!
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
DCArt ( ) posted Mon, 08 August 2005 at 5:59 PM
I bought Norton Internet Security 2005 and uninstalled it right away and asked for a refund. It wreaked havoc with my system performane. That is two releases in a row, and I'll never buy another Norton product again.
Marque ( ) posted Mon, 08 August 2005 at 6:05 PM
I use the norton antivirus but advise against using any of their other products, too squirrley and they infest your system. Marque
layingback ( ) posted Mon, 08 August 2005 at 6:26 PM
Ah, had EXACTLY this problem with P6 - and with some versions of P3DO too.
If you have a Logitech mouse driver, get the latest version, and then on the Motion pane UNcheck the new option "Disable acceleration in games." Apparently this feature - to add acceleration to games - was added several driver versions ago and caused slow downs in 3D apps using OpenGL. It wasn't until the latest version of the driver that they provide an option to revert to the older (pre '03) functionality.
Once I'd upgraded and unchecked, everything was fine in all applications - except my mouse was a little faster everywhere - so I had to reduce it from flat out where it had been forever to about 66%!
PXP ( ) posted Mon, 08 August 2005 at 7:36 PM
Thanks to everyone for so much help. I will take note of suggestions regarding Norton and yes I am using a cordless mouse and it is a Logitec. Layingback I will try following your advice with new Logitec drivers. Where is the option to 'Disable acceleration to games' located please? PXP
maclean ( ) posted Mon, 08 August 2005 at 7:52 PM
I use a logitech cordless mouse and cordless keyboard. After my initial experience, I never installed the Logitech software again for either of them. Nothing but a pain. Both work perfectly well without it. Unless you want the dorky features, like shopping from the kb buttons. That's something I've happily lived without for 4 years now. mac
layingback ( ) posted Mon, 08 August 2005 at 9:05 PM
PXP: Control Panel > Mouse > Motion pane/tab under Cursor Speed and Acceleration. Maclean: I'd agree with you, but as I have their trackball (same drivers) to reduce wrist ache, I do need a few of their parameters. But I agree their installers are pretty pathetic - unloading unwanted "give-aways" is bad enough, but being expected to hand edit the .ini files after install for the trackball is beyond the pale!
blonderella ( ) posted Mon, 08 August 2005 at 10:10 PM
PXP...I agree with others about Norton...I have Norton Internet Security, and I'll never buy a product from them again...after this one expires (maybe even before), I'm gonna find something better...which shouldn't be hard I'm sure... something to also check if your system starts lagging, is go to your Task Manager (CTRL + ALT + DEL) and under the Processes tab, see if CCAPP.exe (which is some component of Norton) is maxing out your CPU usage...this happens to me daily and I have to reboot to correct it...like I said, Norton's going bye-bye asap!
Say what you mean and mean what you say.
Gareee ( ) posted Mon, 08 August 2005 at 10:34 PM
Worst logitech story.. I bought an ifel mouse.. one with vibration effects. They wrote a xp driver, but did NOT include the ifeel ability! Also, thier keyboard drivers do not allow you to turn off their "f lock" keys for extended functions. I'll never buy another logitech device. And another thumbs down here to Norton.. unless of course you need a system slowdown.
Asciicodeplus ( ) posted Mon, 08 August 2005 at 11:39 PM
Norton used to be fine, but that was b4 NAV 2003, at least for me, with Poser 6 I've only had over heating probs that require to cool down the 'puter first b4 trying to use it again, but that's only when I'm using a bunch of figures in the same scene, in most cases the machine suddenly reboot without warning but that's 'cuz I'm using a 2100+ with a standard heatsink . . .
Magik1 ( ) posted Tue, 09 August 2005 at 1:27 AM
Yeah, I'v got a Logitech cordless mouse (Mx Lazer) Make sure that your base unit is within range of the mouse, I was having problem's and found that a move of just 1/2" made all the difference. Also I'd NEVER touch anything NORTONS again!!Once bitten and all that!!! it's been AVG for me for the past 2 years...Sweet as' !!
aeilkema ( ) posted Tue, 09 August 2005 at 7:55 AM
I've got a logitec cordless mouse too, but never installed the original drivers. I let windowsXP handle the installation, it recognized the mouse without installing any logitec drivers. I've been running P6 from the beginning it was released, installed sr1 as soon as it was available and I haven't had any problems at all. Uninstall those drivers for sure to see what effect it will have on your system.
Food for thought.....
bluecity ( ) posted Tue, 09 August 2005 at 6:44 PM
I've had problems in the past with the Norton Internet Security suit slowing everything down; it is so dialed up, it practically stops any network traffic and drags the computer to it's knees. P6 occasionally will check to see if any other computers are using it's serial number, so it could be hitting the firewall and cause it to slow way down.
