Fri, Nov 8, 5:50 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 08 4:41 am)
Subject: Question for content sellers
draculaz ( ) posted Mon, 22 August 2005 at 5:50 AM · edited Fri, 08 November 2024 at 5:42 AM
Just wondering, how do you work your textures? Like where do you find them, do you take them yourselves, do you make them yourselves, etc? drac
Jaymonjay ( ) posted Mon, 22 August 2005 at 7:21 AM
My Bryce content uses textures straight outta the DTE. Textures for my Poser stuff I make in Photoshop, and are usually based off of photos I have taken.
drawbridgep ( ) posted Mon, 22 August 2005 at 7:28 AM
I don't think I would feel right using a texture or a photo created by someone else and then turn around and sell the model. So far I've used tweaked DTE textures, or photographic ones that I've made.
Phillip Drawbridge
Website
Facebook
draculaz ( ) posted Mon, 22 August 2005 at 9:28 AM
well obviously. my question was more towards the process you use in order to acheive those. like for instance can you import images into the dte? thanks
drawbridgep ( ) posted Mon, 22 August 2005 at 9:31 AM
THAT would be uber cool But I don't think you can. A mixture of photographic and DTE. My mouth is watering just thinking about it.
Phillip Drawbridge
Website
Facebook
draculaz ( ) posted Mon, 22 August 2005 at 9:42 AM
so it's all just randomized crap then? that sucks.. drac (with issues)
ysvry ( ) posted Mon, 22 August 2005 at 12:21 PM
diolma ( ) posted Mon, 22 August 2005 at 3:18 PM
NO! Drac, you know better than that! It's NOT just "randomised crap"! It's VERY CAREFULLY, WELL THOUGHT OUT, DTEdited randomised crap! Cheers, Diolma:-)) (with apologies to all involved..)
Jaymonjay ( ) posted Mon, 22 August 2005 at 6:52 PM
I often use a procedural for the diffusion and an imported jpg for bump, etc. You needn't be stuck with only one or the other.
Meshbox ( ) posted Mon, 22 August 2005 at 7:00 PM
Hand made in Photoshop, but our models are distributed primarily in 3DS format so that they are broadly compatible with other tools. Best regards, Chikako Meshbox Design http://www.meshbox.com
Best regards,
chikako
Meshbox Design | 3D Models You Want
Zhann ( ) posted Mon, 22 August 2005 at 7:23 PM
Some of mine are totally DTE, others are photograph based.
Bryce Forum Coordinator....
xenic101 ( ) posted Mon, 22 August 2005 at 9:27 PM · edited Mon, 22 August 2005 at 9:28 PM
Keep in mind that you have 4 texture channel for each material.
Also keep in mind that you can blend channel a and channel b by either ctrl+clicking in the b column for an altitude based blend or ctrl+click in column c for a blend based on the alpha of c.
Also keep in mind that textures which are purely procedural are nmm mmmmmmmmm mmmmm m.m. mmmmmmmmm mmm. Mmm! MMM?
Message edited on: 08/22/2005 21:28
Dann-O ( ) posted Tue, 23 August 2005 at 6:44 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1030191
I have been doing a mix of procedural and my own pics. You need to make a mask for the pic in photoshop. It also helps if you......UV the model. (I hate it but I have found an easier way now) Then you add the picture texture and the mask in a channel higher than the DTE texture. (ie you have a DTE texture in A then you put your mask and pic in B) etc. I used that trick here. I have been lookign for a good way to combine both this seems to work it is a pain overall but it works out ok.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the person next to me.
pidjy ( ) posted Mon, 29 August 2005 at 5:31 AM
Most of my textures are photograph based or painted with photoshop.. and I can see the difference with procedural textures.. for a realistic render/image I (allmost) only use photos ( of mine )
