Bryce F.A.Q (Last Updated: 2024 Nov 07 11:36 pm)
Hand made in Photoshop, but our models are distributed primarily in 3DS format so that they are broadly compatible with other tools. Best regards, Chikako Meshbox Design http://www.meshbox.com
Best regards,
chikako
Meshbox Design | 3D Models You Want
Keep in mind that you have 4 texture channel for each material.
Also keep in mind that you can blend channel a and channel b by either ctrl+clicking in the b column for an altitude based blend or ctrl+click in column c for a blend based on the alpha of c.
Also keep in mind that textures which are purely procedural are nmm mmmmmmmmm mmmmm m.m. mmmmmmmmm mmm. Mmm! MMM?
Message edited on: 08/22/2005 21:28
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1030191
I have been doing a mix of procedural and my own pics. You need to make a mask for the pic in photoshop. It also helps if you......UV the model. (I hate it but I have found an easier way now) Then you add the picture texture and the mask in a channel higher than the DTE texture. (ie you have a DTE texture in A then you put your mask and pic in B) etc. I used that trick here. I have been lookign for a good way to combine both this seems to work it is a pain overall but it works out ok.The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the
person next to me.
Just wondering, how do you work your textures? Like where do you find them, do you take them yourselves, do you make them yourselves, etc? drac
