Thu, Jan 23, 2:53 PM CST
Subject: Underground Complex
Garic ( ) posted Tue, 23 August 2005 at 1:12 PM · edited Thu, 23 January 2025 at 11:33 AM
Attached Link: http://www.garicstarr.com
I am creating a set for my project and it requires a fairly large underground complex. I want to see exposed rocks since the people inhabiting the caves are rebel-military types in hiding.
I have Davorama's sci-fi construction set as well as Redhouse Studios Olympus Mon as construction peices. But what would you suggest as a technique to create rock walls? I will be using vue when the software arrives, but I'm creating the set in poser for import.
Any and all suggestions are welcome.
Message edited on: 08/23/2005 13:19
randym77 ( ) posted Tue, 23 August 2005 at 1:23 PM
RuntimeDNA has an underground tunnel construction set. It's called "Passages."
mrsparky ( ) posted Tue, 23 August 2005 at 8:18 PM
Not rocks. But these may help you.... http://market.renderosity.com/softgood.ez?ViewSoftgood=39424 or http://market.renderosity.com/softgood.ez?ViewSoftgood=33657 or http://market.renderosity.com/softgood.ez?ViewSoftgood=33552 or http://market.renderosity.com/softgood.ez?ViewSoftgood=32830
animajikgraphics ( ) posted Tue, 23 August 2005 at 8:48 PM
You could create the rock wals in Vue using a terrain on it's side. Use 2, one for each side.
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
AntoniaTiger ( ) posted Wed, 24 August 2005 at 1:16 AM
Check the P5/P6 freebies at RDNA -- there's a whole range of materials including various sorts of stone. Displacement maps will do a lot to turn a smooth tube into something a bit uneven, and even the Tile shader, with mortar width set to zero and a bit of tweaking of the settings, can give an irregular pattern which still has the feel of being hacked out of rock by machinery.
