Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Not rocks. But these may help you.... http://market.renderosity.com/softgood.ez?ViewSoftgood=39424 or http://market.renderosity.com/softgood.ez?ViewSoftgood=33657 or http://market.renderosity.com/softgood.ez?ViewSoftgood=33552 or http://market.renderosity.com/softgood.ez?ViewSoftgood=32830
You could create the rock wals in Vue using a terrain on it's side. Use 2, one for each side.
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
Check the P5/P6 freebies at RDNA -- there's a whole range of materials including various sorts of stone. Displacement maps will do a lot to turn a smooth tube into something a bit uneven, and even the Tile shader, with mortar width set to zero and a bit of tweaking of the settings, can give an irregular pattern which still has the feel of being hacked out of rock by machinery.
Attached Link: http://www.garicstarr.com
I am creating a set for my project and it requires a fairly large underground complex. I want to see exposed rocks since the people inhabiting the caves are rebel-military types in hiding.I have Davorama's sci-fi construction set as well as Redhouse Studios Olympus Mon as construction peices. But what would you suggest as a technique to create rock walls? I will be using vue when the software arrives, but I'm creating the set in poser for import.
Any and all suggestions are welcome.
Message edited on: 08/23/2005 13:19
