Sun, Jan 26, 1:28 AM CST
Subject: Tip: Making Black Hair Maps Sandy Brown, or any red.
byAnton ( ) posted Wed, 24 August 2005 at 5:27 PM · edited Sat, 25 January 2025 at 6:31 AM
First off let me say this is a quickie render with Miki. Not doing her justice in this render. I really should have morphs the hair or make her smile or at least use shadows and nice lighting. But I didn't. :) no time. Point being to insert 2 nodes to make her included hair maps any color. I'll start with browns. Insert these two nodes between the hair map and diffuse color Then change the diffuse and highlights colors. Just that simple. You can make any red you want too. This can be done on any figures maps, even animals. Koz hair especially. Not that huge map packs aren't fun, but it just is a great way to do it yourself if you want and save on resources and Cash! have fun! Anton I'll be back with blonde when I get more time.
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
byAnton ( ) posted Wed, 24 August 2005 at 5:28 PM
here are nodes added and values/colors
ps; ANyone see Battlestar Galactica? Sharen?
Tashar59 ( ) posted Wed, 24 August 2005 at 5:48 PM
"ps; ANyone see Battlestar Galactica? Sharen?" That's what I thought too. Put the same hair Sharen has on Miki and you have an instant clone. Great tips by the way.
byAnton ( ) posted Wed, 24 August 2005 at 5:52 PM
btw: For those that don't know her, this is the character "Sharen".
BastBlack ( ) posted Wed, 24 August 2005 at 9:46 PM
I saw a morph today for either Teri Yuki high res or Miki that looked alot of Sharon! i don't know if it was the creator's intension or not. Good show, btw. that blonde cylon is so creepy! :D bB
Acadia ( ) posted Thu, 25 August 2005 at 12:06 AM · edited Thu, 25 August 2005 at 12:07 AM
I sorta kinda understand what you just did there :)
However, I'm lost too....
That silver/black pattern in the middle, and the black pattern to the far right....are those things that came with the hair you are trying to rehue or are they something you created yourself to use?
I was trying to figure out how to rehue a hair the other day and I opened up the Material room and had no clue what to do. I didn't see anything like those other patterns you have in the middle and the far right. All that was there is the window like you have on the far left. What I did was to click on the hair and changed the colours in those too colour boxes in your image to the far left. But that only changed a section of the hair.
Part of my problem is is that I don't know what all that "stuff" there is. I don't know what each of those lines are for in that window to the far left, or why they are there or what they are supposed to do.
Message edited on: 08/25/2005 00:07
byAnton ( ) posted Thu, 25 August 2005 at 12:33 AM
The highlighted areas of the Material Window are things I added/changed in the default Miki Material using the default Black haired maps that came with her. The HSV node controls Hue/Saturation/Value. The Math function is altering the contrast/Brightness of the black map. The images in the node are preview displays of what the node is doing. You can just copy what I did in the picture and you will get the same affect. Again, just thehighlighted elements are all you need to add/change.
byAnton ( ) posted Thu, 25 August 2005 at 12:35 AM
Linda, with the node set up above, you can just change the disffuse color when you want a new color. The rest you can leave alone when you are done setting it up. Then save as a collection into the Matrial Library.
byAnton ( ) posted Thu, 25 August 2005 at 12:40 AM
AKmaterialroombookmark
an0malaus ( ) posted Fri, 26 August 2005 at 5:40 PM
Anton, thanks for this info, it will certainly save the time I spend generating new texture maps by exactly the kind of brightness and contrast adjustments you're doing here (with maybe a spot of colour involution thrown in for colour adjustment). I must ask though, what the effect of having the Hue value greater than 1.0 does? The P6 manual (known for its helpful detail and 100% accuracy, LOL) describes the Hue setting as ranging between 0 and 1.
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
byAnton ( ) posted Mon, 29 August 2005 at 7:02 AM
Having Hue above 1 just seesm to wrap around the spectrum again. :) Whatever works right. hehe
Acadia ( ) posted Mon, 29 August 2005 at 12:47 PM
I've had one walk through in the Material Room on Saturday, and now looking at those screenshots, I actually understand what is going on :) I see that when I do starting working in that room, I'll have to reposition the windows and work from left to right instead of right to left as in the screenshots. To me it makes more sense to see how something starts on the left... ie: the black texture, and how the added nodes and adjustments make changes and ultimately progress to a final result on the right instead of vice versa. I think that is part of the problem. I've been trying to read them from the left when in fact the way they are layed out in most screenshots is to be read from the right.
byAnton ( ) posted Mon, 29 August 2005 at 12:52 PM
I see what you are saying. Follow the plugs. They all lead to the root so reading from left to right helps you see what is being combined usually.
Acadia ( ) posted Thu, 09 February 2006 at 4:16 AM
byAnton ( ) posted Sun, 16 April 2006 at 4:00 AM
Related threads including this one.  Click images to enlarge
Normalizing Highlights with nodes
http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2643355&page=1
Making Black Hair a new color with nodes
http://market.renderosity.com/mod/forumpro/showthread.php?message_id=2385752
Changing Yuki's red hair into Brown with nodes
http://market.renderosity.com/mod/forumpro/showthread.php?message_id=2384534
