Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Feb 08 3:14 pm)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
What are your mesh objects? It may be possible to model them directly in nurbs. If you have to match the mesh model closely then these are some options: Geomagic and RapidForm both have semi-automated tools to convert meshes to nurbs; however, both programs are close to $15,000 dollars. A much more affordable solution uses a nurbs modeling app (such as Rhino, FormZ, Amapi, VectorWorks, to name a few) to make a series of sections through your mesh model and then tracing the sections to create nurbs contours. Then the contours can be lofted (or skinned) to create a nurbs surface. Rhino has a plugin called Smurf that assists in the creation of the contours. Chris
I'm in the process of creating a new product, and I've come to a brick wall. I need to know if there is a way to convert mesh objects into nurbs.
