Sun, Jan 26, 7:33 AM CST
Subject: Question about this weeks Renderosity freebie....
Acadia ( ) posted Wed, 07 September 2005 at 1:43 PM · edited Sun, 26 January 2025 at 7:32 AM
It's a .psd file of tatoos. How does that work exactly? I mean figures are in all different kinds of poses, how do you get a realistic placement of an static overlay tatoo in a graphic program?
originalkitten ( ) posted Wed, 07 September 2005 at 1:45 PM
bookmarking
"I didn't lose my mind, it was mine to give away"
Merlin ( ) posted Wed, 07 September 2005 at 1:53 PM
I guess i'd place the tattoos on the character's texture... Could need a little adjustments according to the character and the spot you put it on, though.
xantor ( ) posted Wed, 07 September 2005 at 1:57 PM
In poser 5 and 6 you can use a blender node to add the tatoo to the figure, the psd file is not meant for a graphics program.
las_61 ( ) posted Wed, 07 September 2005 at 1:57 PM
you would bring the texture you are going to use into your 2d program,( PS or PSP ) and then overlay the tatoo you want, adjust it to scale, etc., and save it out . Then just apply that texture you saved to you fig.
Mystic-Nights ( ) posted Wed, 07 September 2005 at 2:01 PM
Open your skin texture in Paint Shop Pro or Photoshop, Apply the tatoo to the texture and save as a new filename, keeping the original file as is for future use. You would need a mat pose for too I believe. You could use the existing one and edit to the texture file just created.
xantor ( ) posted Wed, 07 September 2005 at 2:29 PM
I still say my answer is the correct one.
SeanMartin ( ) posted Wed, 07 September 2005 at 2:56 PM
It's a psd file, Xantor. That's a photoshop file, no matter how you cut it.
xoconostle ( ) posted Wed, 07 September 2005 at 3:02 PM
Doesn't Poser read .psd files? I believe it does for backgrounds ... haven't tried them in the Materials Room yet. It's true that you can add tattoo images to existing mesh textures in Poser, but alignment can be quite tricky. Unless you want to apply the tattoo across a challenging seam, it'd probably be easier to edit the .psd file in Photoshop for correct size, then add it as a layer to a Poser figure texture. Blend "to taste," probably at about 90% or so. Remember that tattoos aren't opaque decals slapped on top of skin. A tiny bit of blur may also enhance realism.
nruddock ( ) posted Wed, 07 September 2005 at 3:04 PM
Acadia ( ) posted Wed, 07 September 2005 at 3:19 PM · edited Wed, 07 September 2005 at 3:19 PM
Too complicated. I don't know how to make textures. I can't figure out that MAT Pose Edit program, and saving a .jpg to the textures folder doesn't work unless you do that Mat Pose Edit thing.
So I guess I'll pass on this weeks freebie.
Message edited on: 09/07/2005 15:19
dialyn ( ) posted Wed, 07 September 2005 at 4:02 PM · edited Wed, 07 September 2005 at 4:04 PM
You can use PSD files in Paint Shop Pro. Using layers, you can, with a little manipulation (easier to do if you have PSP 8 or 9 but possible in other versions, and Photoshop as well, of course), you can apply the tattoos on a rendered graphic, and use blending techniques in your 2D program to make it look more realistic.
You don't have to make a texture to use the tattoo. You can take an existing texture, apply the tattoo, and then use the texture as you normally would in Poser. It takes some practice, maybe, but it isn't all that complicated if you keep it basic. Of course you can't sell or share a texture that you've used in this manner...
Or you can take a look at Xena's tutorial on applying tattoos. I think she does a good job of making it less confusion and not complicated at all: http://www.wicked-womyn-lair.com/tut-tattoos.php.
If it is any comfort, there is more than one person lost with all the blender node stuff.
Message edited on: 09/07/2005 16:04
elizabyte ( ) posted Wed, 07 September 2005 at 6:39 PM
I'm going to sound like a complete airhead, but, errr.... where is this freebie? Renderosity has weekly freebies? (Somebody blow in my ear, I need a refill.) bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
nruddock ( ) posted Wed, 07 September 2005 at 6:45 PM
I think the newsletter must go out in alphabetical order, as people always seem to post something about them long before I get my email.
Acadia ( ) posted Wed, 07 September 2005 at 6:57 PM
If anyone wants me to forward a copy of my newsletter, PM me your email address and I'll send you a copy of mine. As for the order? Alphabetical sounds about right. I'm near the front of the alphabet.
zulu9812 ( ) posted Wed, 07 September 2005 at 6:58 PM
Wierdly, the freebie link in the newsletter doesn't work for me and none of the images that are supposed to be in it are showing up
ringbearer ( ) posted Wed, 07 September 2005 at 7:20 PM
The read me file for the tattoos explains how to use and apply the tattoos. The layers are even labeled for the body parts to make it even easier.
There are a lot of things worse than dying, being afraid all the time would be one.
elizabyte ( ) posted Wed, 07 September 2005 at 7:20 PM
Oooooh. In the newsletter. D'oh. smacks air-filled forehead Right. bonni
danamongden ( ) posted Wed, 07 September 2005 at 10:24 PM
Not that I'm about to do a blender node tutorial, but the blender node is superior. If the tattoo is at a high resolution (don't know -- haven't gotten my newsletter yet), then you can scale it down in the material room, position it, etc. and have it applied via the blender node. This can give effectively give you the tattoo at a much higher resolution than the underlying skin texture due to the scaling. That's important if you're doing a closeup.
svdl ( ) posted Thu, 08 September 2005 at 12:22 AM
Agree about the blender node. I've used it this way before to add second skins and scars to a skin texture. And since the tattoo is "stand-alone" you can also play with bump/displacement (not very useful for a tattoo, but definitely useful for second skin/scars/wounds)
My gallery   My freestuff
xantor ( ) posted Thu, 08 September 2005 at 5:56 AM
I only got the newsletter today and it said the file is for photoshop, but you can still apply it using a blender node so I was mainly right.
vilian ( ) posted Thu, 08 September 2005 at 8:17 AM · edited Thu, 08 September 2005 at 8:22 AM
Attached Link: http://www.renderosity.com/tut.ez?Form.ViewPages=60&Form.sess_id=48853234&Form.sess_key=1126183107
It doesn't matter it says it's for Photoshop. It's a .psd file and it works just fine under my old PainShopPro 7. It's a little hardcore I'd say - 9 layers, 3000x4000, 99,1 MB in RAM. Tattoes are arranged on Unimesh body texture shape and every one of them is a separate layer. Acadia - just copy a layer that interests you the most and do a "paste as new layer" on bodytexture you use most often. Save it under new name and re-edit existing MAT pose in text editor to point to your new texture (let's say it points to Runtime:Textures:V3:prettybody.jpg, and your new texture now lying in the same folder is named prettybodytattoo.jpg, so you have to replace the first with the latter so all paths looks like this Runtime:Textures:V3:prettybodytattoo.jpg). It's just that easy. Or write a new MAT pose, MAT Pose Edit is very easy to understand, there's an excellent tutorial explaining it here at R'osity in Tutorials.
Message edited on: 09/08/2005 08:19
Message edited on: 09/08/2005 08:22
Outdated gallery over at DeviantArt
Fics at FanFiction.net and Archive of Our Own (AO3)
zulu9812 ( ) posted Thu, 08 September 2005 at 8:19 AM
btw, my newsletter was wonky - none of the links work. Could someone please post the freebie link here or IM it to me? Thanks
SkyeWolf ( ) posted Thu, 08 September 2005 at 9:07 PM
LOLs at bonni :D Awake now dear?
Admin: http://www.artistsagainstcensorship.com
Artist: http://www.skyewolfimages.com
