Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1068378
Well, I'm not sure I'd call mine "really well executed", but here is one I did the other day. (Warning Nudity) I wasn't intending to do a good "art" pic, per se, but rather playing with IBL and AO with an attempt at indoor realism using only a minimal lighting setup. If you want to know more, I can post the light settings and the probe I made myself.Renderosity forum reply notifications are wonky. If I read a follow-up in a thread, but I don't myself reply, then notifications no longer happen AT ALL on that thread. So if I seem to be ignoring a question, that's why. (Updated September 23, 2019)
Attached Link: http://www.renderosity.com/gallery.ez?ByArtist=Y&Artist=Mec4D
Have a look at Cath's gallery, she did some nice examples of integrating Poser renders in photographs using IBL/AO.Content Advisory! This message contains nudity
Hope this helps show what you can expect from IBL and AO.
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1068586&Start=1&Artist=dlfurman&ByArtist=Yes
Here's one recently posted."Few are agreeable in conversation, because each thinks more of what he intends to say than that of what others are saying, and listens no more when he himself has a chance to speak." - Francois de la Rochefoucauld
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Attached Link: http://www.physicalc-software.com/tutorials/ibl/
I use a slightly modified version of the traditional IBL technique which IMO gives much better specular effects and shadows - which uses a modified version of stewers poor-man's IBL script (so above link for the technique). I also find that the material based AO is a) faster, and b) gives much more control than light base AO.Message edited on: 10/19/2005 16:20
Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
The image was actually made for another scene. So it is not "accurate" because it doesn't reflect the actual surroundings of this scene. But it doesn't really matter that much. It produces a believable indoor lighting. I'm now experimenting with making more custom light probes. (The red corners are the result of a red object behind the mirror ball in the scene I used to make the probe. Poser doesn't look in the corners so it doesn't matter.)
Anyway, set up an IBL light with this image plugged into the Light Color. Set the Light Color to WHITE. I used intensity 37% - any values around 35% to 55% work well. Set IBL COntrast to 1. On this light, enable Ambient Occlusion. I used a strength of .25 and left the Scene AO Options at the default values.
Set up a second light to bring out highlights. It can be infinite or spot. In this image it was a spot light with depth map shadows. Do not turn on AO for this light. Intensity was 44%. Angle start/end was 0/130. Distance Start/End was 0/0. XYZ Rotate was -45/38/-12. XYZ Translation was 10/14/10.
Play around with the values. Do fast renders with no raytracing to get the desired light levels right. Then turn on raytracing to enable the AO function. Unless you want reflections in the scene, you can set the raytrace bounces to 0 for faster rendering.
I know there are better setups, as face_off has shown. But since you asked, I tell :)
Now I'll "pose" another teaser - do you want a mini-tutorial on how to use a mirror ball to render your own custom light probes in poser?
Hey baggins - what a cool idea. Build the room scene - then put a 100% reflective sphere in the middle, and render with the camera pointed on the sphere. Gives an IBL image generated from the actual scene!
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=945840&Start=1&Artist=ghelmer&ByArtist=Yes
I'm kinda fond of this pic I did a while back... Only thing I didn't like about was V2's neck looks a little wonky!The GR00VYย GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
Baggins - what about making the reflection sphere very small (scale to 10%) - then you can get the camera closer to the sphere. Was thinking about this some more - the IBL Image should create very bright areas for light sources. However rendering a light in Poser doesn't actually render brightness (ie. it doesn't actually render the light - just the result of the light hitting something). To get around this, you really need to add a props at your lightsources, and have them set to 100% white ambient in the mat room. ....or is the IBL image just a fill light - and you are keeping the main lights in your scene for illumination and shadowing?
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=939313
I use IBL/AO a lot in my renders. Here's one of my earliest uses of it to match scene lighting with a photo background.Tools : ย 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
ghelmer - great render. One question - there is a light in the ceiling to the right - shouldn't that be illuminating her left side?
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1069454&Start=1&Artist=PapaBlueMarlin&ByArtist=Yes
I've really just started using IBL. I use face_off's OcclusionMaster rather than trying to get a universal setting from the lights.Volfin,
You mean www.debevec.org, not "debvec", right?
Your comment about HDR is interesting. I could be wrong, but I don't think it matters in the least that these are not HDR probes.
In fact I'll go this far. I'm going to get heretical here and claim that, with respect to the use of light probes in Poser 6, HDR won't make any improvement whatsoever.
Here are my reasons.
First, Poser can only use a light probe for its calculation of diffuse illumination. That means this is not involved in refraction through dark glass or other tricky situations. It doesn't even use it for specular reflections, which is just plain silly, since it could pretty much use the same algorithm it uses for diffuse, i.e. perform a convolution on the probe and use the surface normal to select a value from the convolution.
Second, diffuse illumination INHERENTLY DISCARDS the detail and range found in an HDR image. Basically, for it to work correctly, it must calculate a "cosine-weighted integral of the corresponding hemisphere of incident illumination." For the math challenged in the room, that means "it must blur the heck out of the probe image first." This destroys a lot of detail, meaning that a low-resolution, LDR probe and a high-res HDR probe end up looking pretty much the same in 99% of situations.
Third, we have no control of the diffuse convolution function used. Which means that the same diffusion angle profile is used for all materials, which is just plain silly. Poser is doing rather inappropriate math on the lighting, so it makes little difference that the input to the lighting algorithm is lacking some detail.
So - we have crappy algorithms, little control on a per-material basis, and only use the probe for diffuse illumination, forcing the addition of other lights to create specular reflections and strong shadows.
Then, on top of all that, the AO algorithms in poser SUCK. It doesn't do the right thing at all. You can see it in how the AO shadows are so grainy and quite often come out the wrong strength at different scales. For example, its very common to get strong AO shadows around the bridge of the nose but give no shadow on the floor under the figure.
I'm just trying to figure out what we CAN do with it, because making truly photo-realistic images isn't going to happen with Poser 6. :-)
Face_off - Yeah I have no intention of modeling the light sources in the IBL probe. I think the IBL is just good for fill. Poser won't use the probe for reflections so there's no point in putting that in there. You have to put other lights in. What IS important, is if there is a light shining on a wall. That matters. For example, in my probe of post #11, you can see a bright spot on the right. That is coming from a light WHICH IS ON THE LEFT. So using this probe, increasing the light on the left increases the diffuse back-fill from the wall on the right! Pretty cool eh? When I use that probe in the scene where it belongs (pinup in a museum), I include the actual spot light on the left. If I change the strength or position of that spot, I have to recalculate the IBL probe. But it really works well. When I finally solve my problems with props in that scene, I'll post it. I wish Poser had a checkbox for "Auto IBL Probe". Then it could just do a quick lo-res render and take care of this all by itself. Its no more difficult than the pre-renders it does to calculate shadow masks.
Baggin's - if you are using this as a fill light - no probs on the other light sources. However, you'll need to get shadows setup on your standard lights - since the AO from the IBL will be very weak (as show in your render above) due to it's low intensity relative to the other lights. If rendertime is no option, can I recommend depth mapped shadows, 0.01 bias, blur 10-20 (depending on the light you are trying to simulate), map size 3072 (very important). If rendertime IS important, you'll need to live with smaller shadow map sizes (1024). Mmmmm, we've strayed a little off topic here....
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=937237
This. Isnt perfect but has IBL and AO. Also the Lagoon light, I remember
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
I've recently started using IBL AO in my pictures and I'm totally in love with the effect!
Here's an example: Lost Boy
And another one here:
Regrets?- - - - - -
Message edited on: 10/20/2005 07:43
You justย can'tย put the words "Poserites" and "happy" in the same sentence - didn't you know that? LaurieA
ย Using Poser since 2002. Currently at Version 11.1 - Win 10.
Here is a test render I did for the tutorial I'm working on. It finished in about 3 minutes. What do ya'll think about this one?
there still seems to be a lack of a "contact shadow" where her body touches the floor
Here is the render with the spotlight shadows turned on and the AO at 20%. I'm using 20 samples on the AO. The AO shadow is dirty. I'm not able to figure out any good settings at all.
I think the AO is crap. Look at all the splotches. And why is there so much shadow on her shoulders. In terms of percentage of occlusion of the hemisphere that lights those areas, it seems totally wrong.
Face_off, I know you said to put AO on individual materials. Can you point to some examples?
BTW: Face_off, I did what you said about the mirror ball. I made it teeny tiny and set the camera focal length to around 15000 mm. Works great! I didn't think poser would do the math for such a tiny object and such extreme focal length correctly but it did. So this lets the camera stay close to the mirror ball.
The thigh material area is showing two kinds of problems simultaneously. To fix one, you must raise bias. To fix the other, you must lower bias. Can't do both at the same time on the thighs, right?
Attached Link: Occlusion master
Im not sure whats going on in your scene there as i dont use any of poser6's render options because i render in Carrarpro4 (animation) and Cinem4DR9 studio( hi res stills) both apps have real GI as well as IBL &HDRI support But the promo images on his store page look pretty good and properly shadowed.I totally get how OM works and why I'd want to use it. But my problem here is I can't find any set of values that works for the thigh. Just the thigh. If I had OM, I'd still have to type in the three values for the thigh and none of them work. Aaarrrgh! Also, I'm a professional python programmer. I can make these scripts myself. But if there is no value for AO options that works for this thigh, then it doesn't matter whether I'm setting them manually or through a script. :)
The settings for AO are:
Strength: .2
Max Distance: .7
Bias: .01
Num Samples: 5
I started with IBL all white. Rendered the ball. Saved the render and attached it to the IBL.
Rendered again (feedback) and saved.
Rendered again and saved final you see here.
This is poor man's radiosity!
I used specular on the ball to pick up the spot light and spread that light around the room while keeping the highlight strong.
Creator
of OctaneRender
for Poser
Blog
Facebook
Attached Link: http://www.physicalc-software.com/forum/viewtopic.php?p=15#15
OK, did a little more testing on this. Light-based AO is very slow compared with your other options. See the above link for details.Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Neverthless, I think Poser's IBL is pretty good. As you can see in this montage, the IBL is contributing most of the total illumination and IMHO is very believable as in the lower right. If I swap the overall ratio to raise the spot and lower the IBL, it just doesn't look as believable. I've collected dozens of indoor photos and the light falloff is much more realistic with IBL. I can't post any of them because that would be a copyright problem.
My problem now is only that to finish the believability we need AO to go with the IBL.
Failing that, I'd like to try the HDRShop conversion of the IBL to a set of infinites as you suggest. But I too ran into the bad link for the plugin.
Sigh.
Even if I get HDRshop working, won't I still need AO to darken the tight spots? I'd still have the same problem with the crappy AO, right? Even in your nice pictures where you demo Occlusion Master, I can see some of the AO dirt. I tried somethings else. I made a shadow-only render to get the AO information and then I softened it in photoshop then multiplied the result back to the original unshadowed image. It improves the results a lot, but I'm trying to find a way around that onerous workflow.
Now that the weekend is upon us, I think I'll just give this a rest and start partying. No more Poser till Monday.
Thanks for all your help!!!!!
Message edited on: 10/21/2005 10:08
As you can see in this montage, the IBL is contributing most of the total illumination IMO, it is better to get > 50% of the illumination from non-IBL sources, and use IBL for the filler. That way you can use the nice depth-mapped and ray-traced shadows. Even if I get HDRshop working, won't I still need AO to darken the tight spots? Not sure what you mean by this. Either use material based AO, or thighen the bias us on the depth mapped shadows (to 0.01). Did you read the link in my previous msg - gives you the values. Even in your nice pictures where you demo Occlusion Master, I can see some of the AO dirt. I doubt it's AO dirt (since there is no light-based AO) - it's probably from the texturemap - that's GI Jill :-)
Creator
of OctaneRender
for Poser
Blog
Facebook
Demi Moore? It is very loosely themed on Demi, but nothing like a genuine attempt to do an accurate likeness.
Creator
of OctaneRender
for Poser
Blog
Facebook
Nice one Jeremy! Does this mean you finally got HDRShop to recognise lightgen? When it's too dark (as above) - up the IBL fill level - see step 6 of the tutorial on how to do this. That will also reduce the impact of the shine. You are right though - in this case it looks a little too shiny - the easiest way to reduce this is to reduce the Oiliness and/or Power sliders in the Realism Kit (Oiliness around 0.3-0.35 would be a good start).
Creator
of OctaneRender
for Poser
Blog
Facebook
I have been doing alot of reading lately on advanced lighting techniques used in theCG Industry particularly Image based lighting and ambient occlusion. it may surprise some to learn that these features are used very heavily by ILM(industrial light&magic) in their CG effects /composite work for starwars and such Poser has this capability but I rarely see it used ( at least in most online poser galleries) anyone have any links to really well executed poser6 renders using IBL and AO thanks
My website
